DIY Skateboard Longboard Riser Lights Angled Riser
39,977
105
29
Introduction: DIY Skateboard Longboard Riser Lights Angled Riser
so i almost got hit by a car the other night on my way to the local walgreens... it was super dark no street lights and i realised i wasnt very visable. i had seen riser lights online... checked them out. too expensive. and i dont like the fact they are not on angled risers. so i decided to build my own. cheap too...
Step 1: Stuff You Need
vitals in this project.
1. set of risers to modify
2. simple switch
3. 2 high intensity wide angle leds
4. 2 small calculator sized batteries
5. dremel with small sanding bit.
6.soldering gun and solder
7. hot glue gun
8. some small section of shipping foam
you can "borrow" some of these things like the leds batteries and switches from electronics around your house.
Step 2: DESTRUCTION MODE.
this step is my fave cause i like to use my dremel. basically you are carving plastic out of certain areas of the riser to create room for the leds wiring switch and batteries
notes:
sector nine risers are what i used they have a good central location for batteries.
make sure you are carving out the correct side for which way you want the leds to face.
one of my wires ran on under side of this picture...
and dont forget to take your time.
Step 3: Led Circuit
so for this next step you may want to draw a small circuit on a piece of paper just for reference. i did just forgot to take a picture of it.
any way you need to solder leds together, the positive from one should be connected to the negative of the second. for more information if you are confused just click here other than that this is a simple step.
notes: make sure your connections are strong. this will experience a lot of vibrations so make certain your connections are solid.
take your time just cause there arent lots of pictures doesnt mean this is a quick step... simple not quick.
you will notice i started using a different switch later in the pictures this is because i broke the two in the first pictures (go me!) trying to rush...
some use resistors, i didnt... still works fine.
Step 4: Show That Hot Glue Gun Some Lovin...
now you need to take everything you have in front of you and smother it in hot glue.... not really... but feel free to make it messy if you need too since you wont ever see the mess again. or atleast until you change the batteries...
i covered the back of the leds in hot glue so if i go threw a puddle of water and it somehow gets wet it wont short out the circuit... i suggest you do the same... hot glue the switch in if theres any wiggle room.
batteries are tricky. first i hot glues the wires to the correct side of each battery. then i taped the batteries together then i hot glued two little pieces of foam to one side to ensure pressure against both batteries...
Step 5: Assembly and in Closing
so the final step is to put it on your board! if your hardware isnt long enough for a riser then go pick some up at the local hardware store...
other than that youre done! test it out...
notes
prob not the best idea for super secret sessions in the middle of the night since it makes you super visable. and easily spotted
mine are really bright pictures dont do it justice
instructions would be the same for front lights i would just use three white leds instead
thanks for checkin out my first instructable!!!
Be the First to Share
    • Fandom Contest
      Fandom Contest
    • Plywood Contest
      Plywood Contest
    • Microcontroller Contest
    29 Comments
    Pocketfile
    Pocketfile
    6 years ago
    Love this, worked out great
    16, 7:20 PM.jpg16, 7:20 PM.jpg
    Navindra
    Navindra
    7 years ago on Introduction
    There is a company that is doing this. And offers a bit more lighting and safety.
    Its called Ekick. This is there website http://www.ekicktech.com its a bit stronger material.
    ezarate
    ezarate
    10 years ago on Introduction
    this is great!
    im planning on adding the blue l.e.d Car light strips onto my board.
    Cann0n
    Cann0n
    13 years ago on Introduction
    A company just marketed these. Sow it on SF
    jonnnyyyzzz
    jonnnyyyzzz
    Reply 13 years ago on Introduction
    Yeah I just started the company. Its called Light Riser. Check it out at www.lightriser.com
    drummonkey92
    drummonkey92
    realy nice idea for the back. i saw some plans for front lights on silverfish that looked pretty impresive though
    quesoman
    quesoman
    i do believe this is a fenominal idea and wish do do this on my board, but why not just carry a flashlight
    albertOMG
    albertOMG
    I would personally try to put another pair of 1/8" riser pads underneath these, to protect from water and dirt coming in through the trucks and into the risers.
    PetervG
    PetervG
    14 years ago on Introduction
    I usually just take a 10mm diffused LED with the battery. Tape them together and like, hot glue it onto my board before going out for a night run.
    AlloySkull
    AlloySkull
    I tried this once, but for another reason. Underglow. Yeah, lame. But I have old longboards and tons of skatboard stuff since I've been skating for a long time and longboarding is my life. I was bored and put blue LEDS inside the riser. Scrapped it because I cruise too much and the cracks in roads really screwed it up. It was the cheapest I could build, anyway.
    Azn Hitman
    Azn Hitman
    What Kind of board do you have?? oh and BTW if you want to buy real ones they are called sunrisers. nice instructable!!!!
    pyrothepenguin
    pyrothepenguin
    Reply 14 years ago on Introduction
    its a gokiburi magic bus. 55" really just a cruiser... good for bombing though... it makes me want to buy a super carving board... like a landyachtz evo or something... and mine is real... not store bought but most certainly real. thanks!
    suggsugg
    suggsugg
    same. I have the loaded vanguard right now. that and a homemade mini for g turns and shuv-its and stuff
    Azn Hitman
    Azn Hitman
    I FINALLY ORDERED MY EVO!!!!!!! what kind of setup do u have on the loaded???
    suggsugg
    suggsugg
    gullwing chargers and abec11 strikers for sliding. Whats your setup on the evo?
    Azn Hitman
    Azn Hitman
    -evo 2008 green tree deck -bear grizzlys -retro big-zigs (80a) -abec 7 bearings how does your board handle DH?
    suggsugg
    suggsugg
    thats an amazing setup. It does ok on downhill going up to 35 (or at least thats the fastest I've gone on it so far.) I want to get an evo for downhill though, I got to try one a while ago at a downhillbillies slalom jam. It had the 96 millimeter flywheels, it was amazing
