DIY Speaker Backpack
Intro: DIY Speaker Backpack
In this instructable i would hopefully so you how you can create your own speaker backpack like the one pctured.
STEP 1: TOOLS, EQUIPMENT, ETC...
the items you will be needing to complete this task are:
TOOLS: sissors
screwdriver
tape (if necessary for taping the speaker contacts)
marker
ITEMS: an old backpack (that you dont mind cutting up)
a old binder for support
a pair of speaker (the size is up to you)
speaker wire
a speaker plate or mount to hold your speaker in place
mini jack cable
mini amplifier
rechargeable battery of 12v (do not exceede 15v)
TOOLS: sissors
screwdriver
marker
speaker wire
mini jack cable
mini amplifier
STEP 2: Chossing Speaker Size and Cutting Hole for Speaker
first thing is to decide on the size of the speaker by check how much room you have where you are going to mount the speakers. i decide to go as big as i can with the speakers on the side of the backpack. i chose 5X7 pioneer speakers that i found at a junkyard inside a ford bronco and i cut out the speaker mounts aswell.
once you choosen the speaker size and have the mount ready its time to mark and cut the holes where the speaker will be positioned and mounted.
STEP 3: Mounting the Speaker and Attaching the Wires
next thing is to attach the speaker wire to the speakers and mount them on the backpack.
you can add a piece of tape to the wire connectors on the speaker for added protection and to keep it in place.
mount the speakers and run the speaker cable to where your amp is going to be. i ran my wire to the front pocket because that is where i have decided to mount my amp.
insert a binder if you want support to keep your speaker facing out.
STEP 4: Wiring Everything Up
now its time to wire the amplifier
STEP 5: Finished Product
the last thing to do is test it out.
51 Comments
popupimusic 3 years ago
And I'm planning to buy a tajezzo music backpack at last
Spyder_2003 7 years ago
how do you charge the 12 volt battery?
Dashing Rainbow Dash 9 years ago
i need to see if i can find this stuff although i do have a pair of computer speakers. they just too quiet for me tho
RogerC1 9 years ago
I have a powersport 12v battery normally used in boats and bikes, would that work too? It has AGM technology, no idea what that means.
Reform 11 years ago
Mr.Bass1010 11 years ago
My next build will happen this year in mid-October and it will be using Logitech's Z506 amplifier module which has an impressive sound power output of 150 Watts total power which will be powered by one Milwaukee M18 54W/hr (or higher W/hr) red lithium 18Volt rechargeable battery. This build is gonna be way much more powerful than any other build I've ever made. The Subwoofer in this build will be a SEALED 270Watts RMS 5.25" extreme Long-Throw High-Excursion Woofer (I've took from an unused RCA Audio System) Which will take place in to a large backpack and will weigh around 20Lbs total. (From the heavy 74 Oz. [4.6 Lbs.] Subwoofer, Batteries, Amplifier Module, and speakers, etc.) I know how to make these things and I enjoy using them. Total system build cost: about $250-$300. Sorry, I don't sell these that I make (mainly because of the way I make them it's very dangerous and power hazardous to pros alike). One thing cool about making a powerful backpack "boompack" is that you can enjoy powerful loud rumbling BASS wherever you go and nobody else really can get them (only if they know how to make one) because major Manufacturer companies don't make these things.
Brandonn151 11 years ago
RemyBordignon 12 years ago
gbmaster137 12 years ago
djvicster130 12 years ago
duckef 12 years ago
juni303 12 years ago
http://www.ebay.com/itm/Mini-Hi-Fi-Stereo-Car-Audio-Amplifier-w-Super-Bass-Out-/280644728772?pt=Car_Amplifiers&hash=item4157bab7c4#ht_2938wt_952
shaneomacmcgee 12 years ago
mwellington 12 years ago
http://www.ebay.com/itm/12V-DC-Rechargeable-Li-ion-Battery-CCTV-Cam-1800mAh-/190459066434?pt=AU_Electronics_Batteries_Chargers&hash=item2c583eb842#ht_2960wt_1139
the second link is to a longer life battery i say about a good 5 hours of play
http://www.ebay.com/itm/12V-DC-Rechargeable-Li-ion-Battery-CCTV-Cam-4800mAh-/250670998641?pt=LH_DefaultDomain_0&hash=item3a5d27e471
nnouhan 12 years ago
Link: http://www.epinions.com/review/pr-RCA_RS2035_COMPACT_STEREO_SYSTEM/content_223680368260
Vijster1 12 years ago
