DIY Survival Bracelet
Intro: DIY Survival Bracelet
survival bracelets can be used in many different ways
1.you can use it for style; they look pretty good
2.you can sell them for about 3 to 5 bucks
3.if u pull the macrame (outer chord) off it turns into a rope for "survival", u can use the inside as fishing line, to tie stuff with, ect.
STEP 1: Starters: Suplies
you will need the following:
1.a pack of 550, 7 strand core paracord (at least 10 feet of it)**
2.a lighter
3.scissors
4.messuring tape
**u can find this at camo country or harbor freight
2.a lighter
3.scissors
4.messuring tape
STEP 2: Prep
cut 2 strings, the 1st one should be around 6 feet long, the second should be able to go 3 & a half times around your wrist
STEP 3: Starting Knot
the bracelets consist of a reg. square knot then u can either use a square knot again or the cobra technique (its easier but takes longer) keep using these knots until there is a loop small enough so that the big knot is able to go through the loop but not come out easiely. cut excess off and burn the ends of the ropes till they turn blackish,then try it on , u have a survival bracelet!
2 Comments
aib192 11 years ago
i like your avatar!
sherrycayheyhey 11 years ago
