DJI Flamewheel LED Lamp
Intro: DJI Flamewheel LED Lamp
This project is a work for wing tip lights for DJI Flamewheel.
Used the materials:
- PCB's 1 pcs
- LED 13pcs (3mm TH)
- Resistor (package 0603) 13pcs
You can use the following formula to determine the resistance value.
R=(VCC-Vd)/Id
VCC= Supply Voltage
Vd= LED Voltage
Id= LED Current
STEP 1:
STEP 2: LED PCB's Production.
Download the GERBER file I shared in the attachment and make the production at a PCB manufacturer. (At this stage, I can offer you www.pcbway.com 10 production price will be 5USD.)
STEP 3: Mounting
- Solder SMD materials with soldering iron or hot air.
- In the second stage, solder the LEDs with soldering iron.
STEP 4: LED Flasher MOSFET Board for ARDUINO Nano
I have designed the mosfet card for the Arduino Nano to make the LEDs the flash features I want.
6 channel mosfet drive.
- Arduino NANO 1pcs.
- PCB 1pcs.
- DTC114YUA 6pcs.
- BSS84 6pcs.
- 10K 0603 Resistor 6pcs.
- 3x7 RA 2.54mm Header
(You can download the Gerber file from the attachment.)
STEP 5:
And Final.
3 Comments
DIY Hacks and How Tos 5 years ago
Nice design. Do you have any more pictures of the assembly process.
caliskan 5 years ago
Hii, thank you.
I've added new photos.
Great. Thanks for updating.
