DS Lite to Gameboy
Intro: DS Lite to Gameboy
Has your top screen of your ds lite broke well don't fret because I have an tutorial on how to turn it into a new Gameboy!
STEP 1: Step 1:
First you must remove all the rubbers front and behind of your broken ds then you must open the screws.You will need a tri-wing screwdiver to open them, once opened you will need to remove the broken top screen of the ds and throw that away.
STEP 2: Step 2:
If your DS just flickers and turns off then you might have to bridge solder these to points.
STEP 3: Finishing Touches
After you have done that you must enclose the ds and screw in all of the screws, make sure it's tight and then there you have it! Your very own SSGBA! (SINGLE screen game boy advance)
23 Comments
Jack Austin 5 years ago
dhiki 7 years ago
mykes1 7 years ago
can you make another version where it work with dsi
ExaviusL 8 years ago
Hey im going to jaycar tomorow and i need to know what resister i should but exacualy.If you can reply with a australian link on the exact resister that will be great.
Rob98000 8 years ago
wes2103 9 years ago
luelusten 9 years ago
The DS fat and DS Lite both are able to be modded like this but you will need a resistor from tests.
AlexK3 9 years ago
My ds doesn't have a gba slot
I think your device is a DSi not a DS then
To the people that want to try this. I have read a few people saying just bridging the connection and they sware it works, in every type of DS and DS Lite I tried this does not work it might be a FW thing when it checks the screen, I have tried resistors low as 160 and they seem to work, I can't state how long it will work for but this did work for me, I also didn't solder mine I want to be able to return the device back to stock if I get bord or need it for testing later so I used a glue gun and made the resistor in to a fork like point so it would hold its own weight and eletic taped the other side.
This mod is greate for units where the touch screen is out and the top screen has died.
M5X6 10 years ago
Vanism 11 years ago
M5X6 10 years ago
Atlas Portal 2 11 years ago
M5X6 10 years ago
M5X6 10 years ago
GTEridan 10 years ago
If not, does that mean you lose sound doing this?
Hennerz19 10 years ago
SwaggerFul Swellow 10 years ago
