Introduction: Da Vinci Popsicle Stick Bridge
Make a self supporting bridge with no mechanical fasteners or adhesives based on one of Leonardo Da Vinci's designs. You will be weaving the sticks together so that the tension between the sticks keeps the bridge together and lifts it off of the ground. You need:
- Jumbo popsicle sticks (colorful ones may be easier)
- Stable working platform
- Patience
The bridge is strong when it comes to downward force but lateral force (from the sides) may cause it to topple. Moving the bridge while it stands (even slightly) could cause it to fall apart, so be careful.
Step 1: Four Sticks
Lay out 4 sticks like picture. You will be weaving the sticks from left to right. The two yellow sticks will be left the footings of the bridge.
Step 2: Add Sticks 5 & 6
Add two additional sticks (red) by weaving them under the green stick and over the orange stick. You may need to hold the orange stick in place while doing this. Notice the bridge starts to lift off the surface at this point. You will continually hold the bridge flat while you add new sticks, this will allow you to more easily add sticks without worry of your bridge tipping over/falling apart. TIP: It often helps to slide the new stick in at an angle to start with.
Step 3: Add Stick 7
Add a seventh stick (orange one) by sliding it underneath the two red sticks.
Step 4: Add Sticks 8 & 9
Weave sticks 8 & 9 (red sticks) under the orange stick and on top of the green stick. If you slowly let go of your bridge after you get these sticks into place, if will raise itself up so that the red sticks make a platform parallel to the ground. You can stop here or keep going to make your bridge longer...
Step 5: Add Sticks 10 & 11
Press your bridge flat again, this will help you keep tension on it while you add new pieces. Add on sticks 10 & 11 (yellow sticks) laying on the orange stick in the space between the outer and inner red sticks.
Step 6: Add Stick 12
Add stick 12 (green), in between red and yellow sticks as pictured. It should be on top of the yellow stick and under the red stick.
Step 7: Add Stick 13
Slide stick 13 (orange) underneath the yellow sticks, parallel to the previous green stick.
Step 8: Add Sticks 14 & 15
Weave sticks 14 &15 under the orange stick and over the green stick.
Step 9: Add Stick 16
Add stick 16 (green) underneath red sticks.
Step 10: Sticks 17 & 18 (last Two!!!)
Weave sticks 17 & 18 (red) under the green stick and over the orange stick.
Step 11: Ta Da!
Gently release the pressure on the bridge and it will rise up. Congratulations! Still want more bridge building excitement? Make your bridge longer, the more sticks you add the more the bridge will curve. How far can you build and still have a stable bridge. Remember: the bridge is strong when it comes to downward force but lateral force (from the sides) may cause it to topple. Moving the bridge while it stands (even slightly) could cause it to fall apart, so be careful. We've found the most successful way to move your bridge is to press it flat and slide it onto a tray/piece of cardboard. Have fun exploring engineering with this activity.
Check out all the neat things we're doing each week in Science City @ sciencecity.com.
2 People Made This Project!
- icey3 made it!
- munsoros000 made it!
15 Discussions
6 months ago
Ich dachte, dass dies zuerst nicht funktionierte, weil ich keinen Kleber verwendete, aber als ich ohne Kleber weitermachte, würden die Eis am Stiel herausspringen. Ich habe Kleber verwendet, nachdem ich versucht hatte, diese Mulitpule-Zeiten zu machen, aber es hat so gut funktioniert!
1 year ago
Nice of you to post this.. Way back in 82 when I was in Boy Scouts we did this exact thing and then made full scale out in the woods.. It was really simple.. However the hard part was figuring out how to keep it intact and get it over the 20' span we built it for without getting wet.. That turned out to be sorta east also.. Need trees on other side. Make a single rope bridge "the hard part was hooking the rope to bring back to our side".. then the 2 lightest went across ( Dale and Me), ran another rope, threw both over some higher branches, then the others tied to bottom of bridge and we pulled while the others lifted the other end.. No live trees were cut down.. And it stayed for 2 years.
Reply 9 months ago
That's amazing. I'd love to try that some time.
1 year ago
Das ist nicht richdickt, es ist schlecht
Reply 10 months ago
Entschuldigung. Wie können wir das ändern?
1 year ago
imposible to make
Reply 10 months ago
Not impossible, just difficult. You can do it.
2 years ago
it is amazing
4 years ago
5 years ago
This is cool! You can build them as big as you'd like with this design! What's the biggest that you've made?
Reply 4 years ago
We doubled our count to 30 before it got too wobbly from side to side force. We started anchoring the four beginning and end sticks with slits & glue.
4 years ago
I did it
4 years ago
made it but cant post a pic
4 years ago
this is imposible to break
5 years ago
Very colorful
