Introduction: Dahlia Paper Flower Wreath
About: Hi! My name is Natalie! I have an awesome husband that lets me be a Play-at-home mom of 3! We homeschool and do projects daily! Check out my blog Doodlecraft for more awesomeness!
Decorate for Spring with vibrant paper!
My friend and I got together to make Rolled Paper Wreaths
for Spring--you can't plan too early, right?!
They are so vibrant, they add the perfect POP to the front door!
You could use Bold reds and Greens to make a Poinsettia for Winter too!
Step 1: Supplies!
56 pieces of lightweight paper
15 Sheets of Martian Green
15 sheets of Terra Green
11 sheets of Pulsar Pink
11 sheets of Plasma Pink
2 sheets of Galaxy Gold (cut in half)
2 sheets of Solar Yellow (cut in half)
Cardboard circle for the backing (mine is 18" diameter)
You'll also need a hot glue/gun
Step 2: Let's Roll!
Start rolling!
Roll the shorter of the sides and pivot while you roll,
so the bottom left corner is the bottom tip of the cone.
It takes some practice, but after 56 rolls...you'll be pro!
After you roll the cone, hot glue the top corner in place.
You are going to cut off the bottom tip in a minute,
so make sure you are gluing at the top of the cone.
Step 3: Gluing
I alternated my greens for variety.
Cut about 2 inches off the bottom of the cones.
Lay them out on your circle of cardboard so you can see how they fit.
Then glue down on the cardboard.
Mine are about 4 inches into on the cardboard, and slightly overlapped,
but shooting out like rays of the sun.
Step 4: Layer Pink!
Then I rolled 22 pinks!
I again trimmed off about 3 inches and glued them around
the cardboard further in the circle.
Slightly overlapping and alternating colors.
I used all but 6 of them. The remaining 6 were cut
another inch shorter and placed inside the center.
Step 5: Yellow Center!
Then I cut 2 sheets of each yellow in half.
Rolled them and added them to the center.
It looked good...but like it needed something.
I took 1 sheet of paper and cut it in half.
then cut slits in it every half inch but didn't cut it all the way through.
Then roll it up--this time just like a tube, glue it in place and curl down the fringes.
And again with another half sheet of the other yellow.
Then I hot glued it right in the center!
Step 6: Hang Up and Enjoy!
Awesome and beautiful!
I just cut a 2 inch slit in the cardboard backing and slipped it right onto an over the door wreath hanger.
Creates the perfect statement on the front porch!
My friend's turned out fantastic too!
She used lots of colors, different sizes and finished her center off with some coffee filter flowers!
I love creating big 3D projects with just simple paper!
