Decorative Sound Absorbing Panels
Intro: Decorative Sound Absorbing Panels
There are many way to improve your home theater, and adding sound-absorbing panels is an inexpensive way of doing it. In my case, it's almost a necessity: the hard concrete walls in my basement home theater have a nasty tendency to bounce sound around in unpleasant ways. The effect was made even worse when the carpet was replaced with hard laminate floors.
The walls themselves were mostly bare, painted concrete. The walls needed decoration - artwork, pictures, whatever. Just something to make the place look less sterile.
My home theater also happens to share a space with the kids' playroom.
So what happens when you put all these requirements into blender and pour the frothy goop into a big, chilled mug? Simple, yet effective child-decorated sound absorbing panels.
STEP 1: How They Work
The purpose of a sound absorbing panel is obvious: it absorbs sound in a room. When placed in strategic locations along the wall, the effect is dramatic. High frequency "ringing" is killed off, and bass is no longer muddy or boomy. All those sound waves that would have bounced off the walls are instead mostly absorbed by the panels, so that the primary wave from the speakers is what you hear most.
The basic construction of these panels is simple, and certainly nothing new. They are simple artistic canvases with thick wood frames, stuffed with sound-absorbing "eggcrate" foam. The panels are decorated to suit the decor of the room. In my case, decorated with the help of my wife and kids, to add colour and fun to our home theater/rec room/play room.
STEP 2: Materials and Tools
- One 1.5" deep art canvas, with dimensions of at least 2x2 feet. I bought mine at a local art store chain called Curry's for about $10 each.
- One 2x2 sheet of 1.5" thick sound absorbing "eggcrate" foam. I bought a whole roll of it online for about $40.
- Acrylic paint to decorate the canvas, from any art store
- Paper backing, to hold the foam in place. You could use old newspaper if you wanted to, as long as it's big and strong enough.
- Picture hangers, two per panel, from a hardware or art store.
And the tools you'll need include:
- Scissors
- Paintbrushes
- Staple gun (to staple the backing onto the frame)
- Hammer (to attach picture hangers)
- screwdriver and/or drill for mounting the panel to a wall
Of course, you'll also need some willing volunteers to help decorate the canvases. If your volunteers are under 5 years old, I suggest doing the painting outside, as the likelihood of spillage and messes is very high. You've been warned!
STEP 3: Paint the Canvases
Another great option is to have cherished photos "printed" on the canvases. There are a few places online that will do this for you - send them your photos, and they'll print them on any size canvas you like. They can even do cool things like spreading the photo across two or three canvases.
STEP 4: Install Foam
So this step is pretty simple. Once the paint is dry on the canvas, flip it over. Simply cut a square (or rectangle) of foam to fit inside the space. It should fill the space completely, but not bulge out. Place the foam inside the canvas with the bumpy side facing the painted face of the canvas.
Now, cut some pieces of paper large enough to cover the back of the panel, but not hang over the edges. Staple the paper down with a staple gun.
STEP 5: Install Picture Hangers
Install the picture hangers in the two top corners. The hangers I used are attached using small finishing nails.
Once the hangers are attached, the sound absorbing panel is ready to mount!
STEP 6: Mount the Panels
I have concrete walls in my basement, so my only choice was to drive Tapcon screws into the concrete. It's messy, but (of course) super strong.
Now, hang your panels on the screws and take a breather - hopefully, the acoustics in the room will be much improved, along with the decor! And, if your kids helped decorate the panels, they'll have something to show off when guests come over to play or watch movies.
36 Comments
gregrogersartifex 3 years ago
gokcen.bilkent 3 years ago
If you are worried about your sound transmitting to your neighbor (or vice versa), you should be taking measures to lower sound transmission. The way to do that is 3 ways: Use thick material, use dense material, use void with insulation.
What to these mean? If you want to sing in your room and want the next door neighbor not to hear you, you should start with rather thick double wall construction, preferably brick or something as dense as brick; and provide sound insulating material (like glass fiber) in between the double walls. The thicker the wall, the bigger the gap between the walls, and the denser the wall material , the less sound your neighbor hear from you.
The type of the sound is also important at this point. Base sounds have long wavelengths, therefor they require even greater space between the walls or they will travel to the neighbor. That is probably why you keep hearing those base bump bumps from your teenager's room.
Now let's discuss Sound Absorption and Reflection: When you speak in a room, it hits to surfaces and it does two things: It either reflects back, or it gets absorbed. If your room has no porous, woven materials like carpets, drapery and textile, it will reflect from all the walls, wood and metal furniture and surfaces such as leather and canvas. If the absorption is too minimal compared to reflection, you'll start hearing echo.
If you aim is to create a quality atmosphere within the room (because you are singing and you don't wanna hear that much echo of yourself), then you'd wanna use a combination of absorbing materials (those sponge like pyramid tiles you see everywhere, or simply carpet, curtain, felt etc) and diffusers. Diffusers are reflective surfaces/parts in different depth and orientation, so they do exactly what the name suggest: they scatter the sound in order to eliminate the flutter.
Ok, what is the take on here: You CANNOT eliminate sound transmission by applying thing absorbent materials on your walls. It will only alleviate the room acoustic quality in YOUR room. Although absorbing material will help the sound to die out a little, it will still hit the wall and transmit to the neighbor's space.
AgnesS24 4 years ago
My tenant complaints about train noise and I was wondering if this solution would absorb some of the noise from the outside?
Also could you recommend website you got your foam from?
Any other ideas how I could reduce train noise and it bouncing off the walls?
jeff-o 4 years ago
r.tan 5 years ago
This method is absolutely ineffective... the sound waves can never reach the absorption foam because canvas doesn't have an open structure. So, the canvas itself will absorb a tiny bit of sound waves but reflects the sound mostly especially when it's covered in paint.
MartinT142 5 years ago
Did you actually do a before/after test? Do you know if there is any difference between just the painting and the painting alone?
June Cora 5 years ago
I am a third grade teacher, recently, I have been placed in a portable classroom smack dab on the playing field next to the PE Pavilion. Not only can the kids watch but the noise is can be deafening. It interrupts the learning. Does anyone have cheap ideas that I can use to quiet the classroom? Please help!!
yucca.htn 7 years ago
That sort of foam doesn't really do much to help room acoustics. Usually a deeper pyramid shaped foam is used to kill higher frequencies and prevent flutter echo, but putting a canvas in front of it would null the effect of the pyramid shape. I would tweak the frame to add more depth and use rockwool or any thick and dense material instead.
ElaineM41 8 years ago
I am going insane in my loft style apartment. my ceilings are 17.5 feet tall. the walls are so thin i can hear the neighbors in their living room talking. kids above me run in the halls and it sounds like elephants. it doesn't help that i have 5 birds. one is an umbrella cockatoo. she is quite for a cockatoo but still loud. what is the cheapest thing i can do to help with the echo? i thought about this before i moved in and tried putting thick quilt batting on the walls. it did nothing but collect dust and look stupid. i love you idea and am going to try it. i also made some fabric covered blue hard foam insulation panels that i need to hang up. it would be great if i could afford to hang fabric from the ceiling to the floor but that would cost hundreds of dollars.
RachelK23 8 years ago
Do you think this would work in a 2 story tall, round silo shaped space? The library where I work has terrible acoustics in our storytime silo. The peaked roof doesn't help either.
jeff-o 8 years ago
Or maybe drape some tapestries across the top of the space like an open, airy tent or market?
SusanF3 9 years ago
I was wondering if the canvas frames didn't partially negate the sound-reducing effect of the foam... And I was also wondering about placement of the panels. Do you experiment with the location?
jeff-o 9 years ago
SusanF3 9 years ago
Thanks!!
Keznaa 10 years ago
Keznaa 10 years ago
jeff-o 10 years ago
CreativeGeek 11 years ago
ToniRose 11 years ago
Shut Up Now 13 years ago
