Delicious Pumpkin Pie With Decorative Pumpkin Platter Cover
Intro: Delicious Pumpkin Pie With Decorative Pumpkin Platter Cover
In this instructable, I will show you how to make a decorative pumpkin platter cover and a delicious homemade pumpkin pie. Pumpkin season is here so its the perfect time for this fun project! The platter cover is a great decoration for any occasion and can be paired with any of you holiday favorites! I chose to use this pumpkin pie recipe with the platter cover because it is one of my favorite fall treats.
STEP 1: Prep for Carving
Find a nice spot outside and lay out some cardboard and put all of your carving supplies and pumpkin on it.
STEP 2: Trace Your Cutout
Grab a pie crust that is 9 inches and place it on the bottom of your pumpkin. Grab a writing utensil and trace about an inch to half inch outside of the pie crust.
STEP 3: Cut Out the Bottom
Cut out the bottom of your pumpkin just outside of the line you had made.
STEP 4: Open It Up
Use something to pry the pumpkin open and pull off the bottom of the pumpkin. You can get rid of the bottom, you will not need it anymore.
STEP 5: Loosen the Seeds
Loosen the seeds from the inside of the pumpkin.
STEP 6: Empty the Pumpkin
Take out all of the seeds from the pumpkin so there is no leftovers inside the pumpkin.
STEP 7: Thin the Walls
Carve the inside walls of the pumpkin to thin the walls to give your pie enough room inside.
STEP 8: Draw
Pick and draw a design on your pumpkin.
STEP 9: Carve
Carve out your design.
STEP 10: Clean Pumpkin
Clean you pumpkin with a water and vinegar spray.
You are done carving! Now to the pie!
STEP 11: Prep Kitchen
Bring your pumpkin inside and measure out your ingredients. Preheat oven to 425 degrees F (220 degrees C.) Place the ice cream near the warming oven to soften.
STEP 12: Eggs
Whisk your three eggs together.
STEP 13: Pumpkin Puree
Add in your pumpkin puree and mix it in with your eggs.
STEP 14: Keep Mixing!
Add in the sugar, salt, cinnamon, ginger, and nutmeg.
STEP 15: Ice Cream
Slowly add in the softened ice cream and stir it in until the mixture is smooth.
STEP 16: Fill Pie Crust
With a ladle, fill the two 9 inch pie crusts with the mixture.
STEP 17: Baking Sheet
Place the pies on the baking sheet.
STEP 18: Bake
Put the pie in the oven and bake for 15 minutes, then reduce the oven tempurature to 350 degrees F (175 degrees C), and bake for an additional 30-40 minutes (or until filling is set.)
STEP 19: Lights
While the pies are baking take your pumpkin and place the LED light in the top. Put skewers in the pumpkin over it to keep it in place.
STEP 20: Lights Cont.
Stick more skewers in the pumpkin over the light to support the light.
STEP 21: Take Pies Out
Pull your pies out and set one on a plate.
STEP 22: Finished
Place the pumpkin over the pie and you are done!
Penolopy Bulnick 3 years ago
