DenCity- a K'nex Ball Machine Instructions
Intro: DenCity- a K'nex Ball Machine Instructions
My latest and most piece- consuming build yet, more pieces than my pinball machine!This ball machine was the hardest to make instructions on since everything was so integrated into each other. DenCity although being dense and all also has 6910 pieces, five paths, a motor that drives four mechanisms, thirty-nine gears and a wide structure. DenCity started out when I made Ionization and decided to keep the gate and lift system and build a new ball machine around it. Then I thought, " how many things can I power with one motor?" This is what came out. A lot of elements came from other member's guides.
This instructable is currently in beta as of descriptions of the paths but all the photos are uploaded.
Also, this is the first instructable where I cropped all the pictures!
Credit goes to yardking42 and Martijnb95 for use of some of their elements.
STEP 1: Piece Count
RODS:
Grey: 27
Red: 148
Yellow: 377
Blue: 988
White: 617
Green: 1198!
TOTAL: 3,355
CONNECTORS:
White: 172
Blue 3D: 265
Yellow: 746
Green: 102
Purple 3D: 458
Orange: 336
Red: 343
Light-grey: 38
Dark- grey: 346
TOTAL: 2806
OTHER/ SPECIAL
Tan-lock: 42
Blue-clip: 23
Y-clips: 64
Silver-spacer: 292
Blue-spacer: 159
Track-splice clip: 1
Red gear: 20
Large yellow gear: 2
Yellow gear: 4
Blue gear: 13
Purple flexi-rod: 25
Orange flexi-rod: 13
Black rod: 4
Tan(red) rod: 8
Small tire: 5
Medium tire: 1
Large tire: 1
Balls: 3+
Chain links: 71
Motor:1
TOTAL: 749
GRAND TOTAL: 6,910
Grey: 27
Red: 148
Yellow: 377
Blue: 988
White: 617
Green: 1198!
TOTAL: 3,355
CONNECTORS:
White: 172
Blue 3D: 265
Yellow: 746
Green: 102
Purple 3D: 458
Orange: 336
Red: 343
Light-grey: 38
Dark- grey: 346
TOTAL: 2806
OTHER/ SPECIAL
Tan-lock: 42
Blue-clip: 23
Y-clips: 64
Silver-spacer: 292
Blue-spacer: 159
Red gear: 20
Yellow gear: 4
Blue gear: 13
Black rod: 4
Tan(red) rod: 8
Small tire: 5
Medium tire: 1
Large tire: 1
Balls: 3+
Chain links: 71
Motor:1
TOTAL: 749
GRAND TOTAL: 6,910
STEP 2: Base
The base is the start of all ball machines. It is also the start of most of the problems I faced when I was structuring the machine itself.
The last pic will explain why.
STEP 3: Gear Mechanisms and Wheel Lift
This step includes all the gears for most of the machine as well as the wheel lift. This step may take you a while.
STEP 4: Main Support, Lift, Motor and Drive-Shaft
Almost done with the mechanics!
STEP 5: Chain-Transport System
The main feature on the machine despite being there only for path 1.
STEP 6: Secondary Supports and Path Selecters
Last long step before the paths!
STEP 7: Path 1
The first path has the most interesting element on the machine, the single-ball block-gate.
STEP 8: Path 2
This path uses Yardking42's Sidewinder element and martijnb95's Gap Element as well as his " Arm With Stop" element.
STEP 9: Path 3
I would call this the lazy path because there is no major elements besides some super path.
STEP 10: Path 4
The phoenix rises again! This uses my favorite element I used in two other ball machines as well as a wheel arm from Davinchi.
STEP 11: Path 5
This path uses super path as well as martijnb95 Zigzag Stairs. There are ball alternators and a small chain path also.
31 Comments
albydesign 10 years ago
sandroknexmaster 10 years ago
I like every machine you built. It's incredible, they're always sturdy and looking good. always cool new elements too. You also work very fast and you keep amaze me with clear, full instructions of the complete machine, every time again.
And this machine proves it again!
Congratulations for being feautured and good job! I voted! :D
knexpert#10829476 10 years ago
Shadowman39 10 years ago
TheKnexDude 10 years ago
Great pun.
zhamster rules 10 years ago
hxwhxw 10 years ago
Voted up and favorited!
hxwhxw 10 years ago
MechanicalCreationMaster 10 years ago
_________________________
MORE! MORE BALL MACHINES!!!!! :-D
Borisv9 7 years ago
really good ball machine! this proves that you dont need a floor to make a good machine! it made me feel really confident about my upcoming ball machine, Journey. Thanks for sharing, good job!
JeffS14 9 years ago
Are the red and yellow balls the same as the black and white balls? I only have the red and yellow ones?
knex akbar 10 years ago
nooo i have all the pieces except for just one large yellow gear!
knex crazy 10 years ago
cool
No, did you build it correctly? This spiral lift is modified to be a little stiffer.
