Deodorant Rocket
22,675
12
34
Introduction: Deodorant Rocket
A rocket powered by aerosol deodorant.
Step 1: Materials
1. Plastic water or pop bottle.
2. Power drill
3. Quarter inch bit
4. Aerosol deodorant or hairspray with butane or propane
5. Barbeque lighter
Step 2: Rocket Nozzle
Take the cap off the bottle and drill a quarter inch hole in the center. This will provide the exhaust flow passage for the rocket.
Step 3: Ignition
Spray a small amount of deodorant into the bottle and screw the cap on. Shake it up to mix the fuel with the oxygen in the air. Hold a lit barbeque lighter next to the nozzle to ignite the fuel and watch the rocket take off.
Step 4: Caution
Don't do this indoors or around people. Don't point the rocket at animals or anything that will break. Don't put anything flammable near the nozzle including your hands.
Be the First to Share
    • Plywood Challenge
      Plywood Challenge
    • Battery Powered Contest
    • Plastic Contest
      Plastic Contest
    34 Discussions
    octavian234
    octavian234
    12 years ago on Introduction
    you could just take the aerosol bottle and wack the top of it off and is co2 flamable?
    Sharvin
    Sharvin
    compressed co2 is used to put out fires lol...
    Boppo3
    Boppo3
    this idea is very primitive, workable yes but dangerous to not only you but others too. So my suggestion? Please, incorporate a more sophisticated ignition system into your barbecue lighter method, so that you and your pals can stand further away at a safe distance to watch your rocket fly. Maybe, you can take apart your lighter, pick out the tiny little piezoelectric sparker and connect a long wire from the tiny sparker to the rocket's thruster nozzle. Then, if possible, build maybe a rail system to help aim your rocket
    But still , this a good try at making a rocket. I just hope no one gets hurt
    dungeon runner
    Someone should make a guide on DIY ballistics. I once saw a book about making these sorts of things, rockets, cannons, trebuchets.
    Are they still allowing users to make guides with admin permission? Or is it an admin only thing now?
    e.montvidas
    e.montvidas
    10 years ago on Step 4
    yeah after what rossag said i am NOT going to add this to the rocket ideas that i might do ....
    and anyway when you spray the aerosol or whatever into/onto something the burning somehow goes away......
    i tried to make a wd-40 rocket, the spay burns nice.....but when you spray onto/into summing then light=no fire=no thrust=me unhappy
    but it's a nice idea....could always try puncturing the bottle then lighting that
    frikkie
    frikkie
    10 years ago on Introduction
    Have not tried it yet.But for warning others you must get a t-shirt that says: Im a bomb technician  if I run... try to keep up!
    mzdzohn
    mzdzohn
    11 years ago on Step 4
     i am sorry to say but it absolutely didnt work :(
    octavian234
    octavian234
    thank you its 1 in the morning and im not thinking straight
    I did this indoors and pointed it at something breakable and put my hand near the nozzle. I got a really bad burn and had it bandaged up for 2 weeks.
    rossag
    rossag
    12 years ago on Step 4
    does not work very dodgey set up the bottle blew up on me
    coatesy900
    coatesy900
    Reply 12 years ago on Step 4
    Try making the hole in the cap bigger.
    pickford78
    pickford78
    try using lighter butane or propane. also they work good attached to a hot wheel toy truck with a trailer attached.
    pyro 360
    pyro 360
    Reply 12 years ago on Introduction
    nice one i done this and used pure butne and propane it worked better than hairsprey
    pickford78
    pickford78
    My latest was oxygen and propane mixed. it worked allot better but the mix was hard.
    Kiteman
    Kiteman
    13 years ago on Introduction
    No photos? No launch video? BTW, these are seriously unpredictable - warn everybody nearby to get ready to run - I once nearly removed a colleague's ear with one of these, and he was sitting behind me.
