Destroy Any Device With EMP Jammer
402,804
532
74
Introduction: Destroy Any Device With EMP Jammer
About: Ideas Into Reality !
Imagine that you have powers to stop any electronic device, is it only possible in movies?
well here's the way to make an emp jammer (Electromagnetic pulse jammer)
This device sends high amplitudes of emp to destroy nearby devices, be sure to have fun using this, but be careful this jammer involves thousands of volts which can lead to heart attack or death even (if not used properly)
DON'T USE THIS DEVICE NEARBY ANY MEDICAL EQUIPMENT LIKE PACEMAKERS ETC.
Watch the video
https://youtu.be/l7UMJL3rB3Q
https://youtu.be/4ldKP0aGIhY
Step 1: Get the Parts
Part list
★☆★ Buy Parts from your online local store ★☆★
1. 32 gauge Magnet Wire http://geni.us/ITPUbly
2. Plastic Project Box http://geni.us/C2eA
3. Push Switch ×2 http://geni.us/TcAmVuf
4. Some kind of glue http://geni.us/FAC7w
5. Hot glue (if you need) http://geni.us/lBnlm
6. 3.7 v battery http://geni.us/8V2i1
7. 7000 volt High Voltage Converter http://geni.us/oFb09C
Step 2: Connecting Togather
make a coil of 32 gauge copper wire with 5 turns connect an push switch (i call it spark gap) and high voltage converter in series with coil.
connect an push switch to control power to the high voltage converter .
Step 3: See the Tutorial
2 People Made This Project!
  • Home Decor Challenge
  • Explore Science Challenge
74 Comments
cyanandspace
cyanandspace
4 years ago
if somebody could make this for me and send it to me, I would be eternally grateful, and it may even come with a cash reward ;)
JonathanF99
JonathanF99
Reply 4 years ago
I did one and it worked, I can sell you one
fixxfan2112
fixxfan2112
Reply 8 months ago
Ill buy it !! How much ??
U.S cash....
Freddyja
Freddyja
Reply 4 years ago
Fjaraalmonte@gmail.com
YaddyVirus
YaddyVirus
Reply 4 years ago
Really?
SteveDay72
SteveDay72
8 months ago
A switch cannot be used as a spark gap - it would melt it. This project is fake.
A real EMP unit would use an off-the-shelf and readily available spark-gap... ie: an engine spark plug. It would charge up a bank of large capacitors and then discharge them through spark-gap(s). House the coil at the back end of a long can and you might be able to make it somewhat directional.
inuyasha1986
inuyasha1986
10 months ago
Ive tried different number of windings, doesnt work. attempting to try another
alexandersobotovic
alexandersobotovic
1 year ago
It's nonsense :-)) A stronger EMP has the ignition coil in the car and nothing happens to it.
lndsoto
lndsoto
1 year ago
How can one defend themselves against these devices?
bilGolden
bilGolden
2 years ago
Is it possible to somehow use a tens unit with a 9 v battery as an emp? Just curious .
Hrishik5
Hrishik5
2 years ago
Can this fry any device using frequency ranges from 3khz to 300 GHZ? If not what frequency range devices will be affected? Message me asap will pay well for this device if it works.
ronm172
ronm172
2 years ago
If you place two magnets in the opposite direction to their first date each other create a magnetic pulse true or false
SurplusS
SurplusS
4 years ago
why higher voltage makes greater magnetic field? Doesn't the higher voltage mean lower current and consequently generates weaker magnetic field?(P = IV, also I can't fully understand how the spark gap plays in the circuit. When there is high voltage, electric can go through the spark gap frequently and that makes a pulse, right?
ronm172
ronm172
Reply 2 years ago
Two magnets facing the opposite way cause a magnetic pulse true or false
ResponseRobot
ResponseRobot
Reply 3 years ago
I believe the spark gap provides quick and easy timing circuit that allows the coil to produce many pulses a second rather than one single long pulse.
6
iceng
iceng
Tip 2 years ago
This is a fake project and CAN'T produce an insect flicker let alone any
Electro Magnetic Pulse ..... to damage semiconductor intrinsic diodes..
Especially the TOY PUSH BUTTONS can't carry any amount of current in the tiny wire or they would Weld Shut if the current was correct..
ienu2306
ienu2306
Question 2 years ago on Introduction
sir ye capisiter kha mil skta h jha me rheta hu wha nhi mil pa rha h ye
PrakharMishra
PrakharMishra
Tip 3 years ago
Use more turns in the coil
