Introduction: Detailed Pandahall Tutorial on How to Make a White Pearl Beaded Collar Necklace
Wanna make a pearl beaded collar necklace by yourself? This detailed Pandahall tutorial will teach you how to make a white pearl beaded collar necklace.
Step 1: Supplies Needed in DIY the White Pearl Beaded Collar Necklace:
10mm White Round Pearl Beads
3mm White Round Pearl Beads
0.2mm Fishing Wire
Needle
Stainless-Steel Scissor
Step 2: Make the First Part of White Pearl Beaded Collar Necklace
1st, cut a part of 0.2mm fishing wire. Thread a 3mm white round pearl bead to the middle of it and fold it into half. Then, hold the two fishing wires together and thread a 10mm white round pearl bead;
2nd, split the two wires apart and thread 5 3mm white round pearl beads to the left wire, 6 3mm white round pearl beads to the left wire;
3rd, cross the left wire through the bottom 3mm white round pearl bead;
4th, thread about 17 3mm white round pearl beads to the two wires respectively;
5th, cross the right wire through the second 3mm white round pearl bead (as shown in the picture);
6th, cross the left wire through the second 3mm white round pearl bead (as shown in the picture).
Step 3: Make the Second Part of White Pearl Beaded Collar Necklace
1st, thread a 3mm white round pearl bead to the left wire. Then, thread 2 3mm white round pearl beads to the right wire;
2nd, cross the left wire through the bottom 3mm white round pearl bead on the right wire;
3rd, thread 3 3mm white round pearl beads to the two wires respectively. Then, cross the two wires through another 3mm white round pearl bead. Thread about 13 3mm white round pearl beads to the two wires respectively (as shown in the picture);
4th, cross the right wire through the 3mm white round pearl bead (as shown in the right red arrow). Likewise, cross the left wire through the 3mm white round pearl bead (as shown in the left red arrow);
5th, thread 3 3mm white round pearl beads to the two wires respectively (as shown in the picture);
6th, cross the left wire through the 3mm white round pearl bead (as shown in the left red arrow). Likewise, cross the right wire through the 3mm white round pearl bead (as shown in the right red arrow).
Step 4: Make the Third Part of White Pearl Beaded Collar Necklace
1st, thread a 3mm white round pearl bead to the two wires. Then, cross the two wires through another 3mm white round pearl bead. Thread 4 3mm white round pearl beads to the left wire and 3 3mm white round pearl beads to the right wire (as shown in the picture);
2nd, cross the right wire through the bottom 3mm white round pearl bead on the left wire (as shown in the picture);
3rd, refer to the above steps to make more such patterns (as shown in the picture);
Step 5:
4th, refer to the above steps to make another such pearl bead necklace (as shown in the picture).
Step 6: Make the Fourth Part of White Pearl Beaded Collar Necklace
1st, take out one pearl bead necklace and thread 7 3mm white round pearl beads to the wire;
2nd, make a hoop with the pearl beads by crossing the wire through the 3mm white round pearl bead (as shown in the picture);
3rd, thread 7 3mm white round pearl beads to the wire;
4th, make a hoop with the pearl beads by crossing the wire through the 3mm white round pearl beads. Then, thread 5 3mm white round pearl beads to the wire (as shown in the picture).
Step 7: Make the Fifth Part of White Pearl Beaded Collar Necklace
1st, cross the wire through the 3mm white round pearl bead (as shown in the red arrow). Then, thread another 3mm white round pearl bead (as shown in the picture);
2nd, cross the wire through the 3mm white round pearl beads (as shown in the picture);
3rd, refer to the above steps to make more such patterns(as shown in the picture).
Step 8: Make the Rest Part of White Pearl Beaded Collar Necklace
1st, take out the other pearl necklace and thread 3 3mm white round pearl beads to it (as shown in the picture);
2nd, cross the wire through the 3mm white round pearl bead on the other pearl necklace. Then, thread 3 3mm white round pearl beads to the wire (as shown in the picture);
3rd, make a hoop by crossing the wire through the 3mm white round pearl bead on the upper pearl necklace. Then, cross the wire through the 3mm white round pearl beads on the loop. Thread another 3mm white round pearl bead (as shown in the picture);
4th, cross the wire through the 3mm white round pearl bead (as shown in the red arrow). Then, thread 5 3mm white round pearl beads to the wire (as shown in the picture);
5th, make a hoop with the pearls by crossing the wire through the 3mm white round pearl bead (as shown in the right red arrow). Then, cross the wire through the 3mm white round pearl beads (as shown in the picture);
6th, thread a 3mm white round pearl bead to the wire and cross the wire through the 3mm white round pearl bead (as shown in the red arrow in the picture);
Step 9:
7th, thread 3 3mm white round pearl beads to the wire and cross the wire through 3mm white round pearl bead (as shown in the red arrow in the picture);
Step 10:
8th, refer to the above steps to make more such patterns.
Step 11:
Well, this white pearl beaded collar necklace is done! It's a bit complicated to make the pearl collar necklace. Please be patient during the beading of the pearl beads. If you're interested in this white pearl beaded collar necklace, just refer to the above tutorial to make one! Have a try!
4 Comments
6 years ago
this is good work I like
Reply 6 years ago
Thank you. Have a nice try, friend.
6 years ago
Wow, you're really good at making jewelry! Like REALLY GOOD, i like almost everything you do! Great work! ;)
Reply 6 years ago
Thank you so much. You also can have a nice try and you can do it. Have a nice day!
