Diffuser (Polarizer) Glasses
Intro: Diffuser (Polarizer) Glasses
As curious as I am, I opened up the LCD screen of an old laptop that would have been thrown away otherwise.
What I found inside seemed to be the most interesting material ever! There were multiple sheets of plastic that looked to be metallic and shiny, but reflected and diffused light in strange ways.
Trying to come up with a fun project, I settled on diffuser glasses.
--I honestly do not know what to call these things, polarizers or diffusers. Whatever they may be, please let me know, so I can put up the correct information!
I'll take you step by step to make these fun, yet disorienting glasses.
Note: I will not be responsible for broken monitors or concussions! :)
What it looks like:
Thank you to my friend for the idea!
What it looks like:
STEP 1: Materials
There is a fairly short list of materials
1. An old laptop or some spare sheets of this diffuser stuff. Old cellphones or anything with an LCD should work.
2. RealD 3D Glasses! (I got mine from Avatar, but really any fairly large glasses without lenses are fine)
3. Flat and phillips head screwdrivers
4. Small pocketknife, or anything with a thin blade that gives you good leverage
5. Scissors
6. White paper
7. Pencil
8. Scotch tape
5. Scissors
6. White paper
7. Pencil
8. Scotch tape
STEP 2: Take Apart Your Screen!
Unfortunately, I don't have any pictures of me taking apart the screen :(
I'm sure there are other places you can attain this material, if there are, leave a comment!
But, it shouldn't be very hard!
I was a little desctuctive while taking mine apart, prying the screen off, because there was nothing else of use on the broken machine.
If you're having trouble you'll find a good instructable to take apart a laptop here: www.instructables.com/id/How-to-Take-Apart-a-Laptop/
1. Just get out a flathead screwdriver, and pry the plastic casing off. Do not worry, there is another metal casing inside.
2. When you take the plastic casing off, you should have something that looks like picture 1.
3. Unscrew this casing apart, separate the parts and sheets, and you'll be left with an array of components, from the backlight, to the sheets we're looking for.
4. There should be two, very hard to describe sheets, that look metallic and shiny, yet are transparent at the same time, just depending on the angle they are looked at. Put these off to the side.
(You can use the LCD panel itself as a cool room ornament, I hung mine in my room!)
5. Proceed to step 3
STEP 3: Prepare the Glasses
Very simple step.
If you just have regular lenseless glasses, go on to step 4
If you have a pair of RealD 3D glasses, you'll notice that they have two layers.
Simply put, you can harmlessly take them apart, remove the 3D polarizers, replace them with our lenses, and put them back together.
1. Get a pocketknife, or anything with a thin blade, and get it in between the two pieces of your glasses.
2. Pry them off carefully, being careful not to break the plastic
3. Separate the pieces
4. Remove the 3D polarizers
STEP 4: Cut Out Our Lenses!
Now, we can cut out our lenses for our glasses.
1. Take the 3D polarizers from the RealD glasses and trace each one individually onto a sheet of white paper.
2. Cut out the paper traces of the lenses
3. Take out your diffuser sheet
4. Tape the white paper onto the diffuser sheet using two pieces of Scotch tape
5. Cut out the lenses using the white paper as a guide.
6. Test to see if our diffuser lenses fit into the 3D glasses, if not, trim them down until they do
STEP 5: Finish the Glasses
Now to finish up
1. Take out newly cut out diffuser lenses, and place them where the old 3D polarizers went in the glasses.
Note: It doesn't matter which side of the lens you put facing in a certain direction. They have different looks from the outside and inside when worn facing different directions, forward or backwards.
2. Put the two pieces together
3. Wear them!
And it's hard to post a picture of what you see when looking through them, because a camera can't quite capture that, so I'll let you figure out!
3. Wear them!
50 Comments
PierreF 12 years ago
But this thin plastic stuff isn't a fresnel lens or a polariser,
but a diffraction grid!
This grid is used in lcd screens to separate colors from the white light, in order to have Red, blue or green pixels! This explain why you can see some "rainbows" with your glasses :)
mhassan5 12 years ago
rix_101 13 years ago
bilham 13 years ago
louieaw 13 years ago
LDDR 14 years ago
milkywaybar 14 years ago
http://www.howstuffworks.com/monitor.htm
frollard 14 years ago
Holding pairs of glasses face to face cancels because it puts a left and a right in front of each other (vert + horizontal) which is opaque, but if you hold the glasses face to face and rotate one pair of glasses it becomes semitransparent based on the angle.
The lenses he is putting INTO the old frames: fresnell lenses.
getack 14 years ago
They are linear. 'never totally opaque' is because they are not perfect polarizers - very few materials are, and definitely not plastic 3 dollar lenses.
http://science.howstuffworks.com/3-d-glasses2.htm
*image blatantly ripped off from the howwstuffworks.com website.
Note the arrows are INCORRECT in this picture - vertical slits allow VERTICALLY polarized image to pass through, not opposite as it shows. Howstuffworks also has the red/blue analglyph glasses image backwards - a red filter only allows the red image through, not the blue image as shown.
getack 14 years ago
Peace
Creamaster 14 years ago
mr_step 14 years ago
There's a short write up on RealD here:
http://en.wikipedia.org/wiki/RealD_Cinema
And circular polarization here:
http://en.wikipedia.org/wiki/Circular_polarization
Circular polarization is somewhat rare in nature, though it is thought some shrimp can actually detect circular polarized light.
just seems it would be hard to produce a circularly polarized lense - only allowing one rotation of em to pass through.
There should be one combination looking through them where it will go completely opaque no matter what hold them. Just flip one around and it will go completely black when trying to look through both no matter how you rotate them. Which is the behaviour mine exhibited.
It's possible some theatres are still using linear polarization if they already had that fitted, but as far as i knew all the new installations were using circular.
They do use the single projector with an alternating filter that alternates the right/left handedness of the image. You can read all about it on the RealD wiki page or on their site.
I kept the lenses to try making a poor-man's polarizing camera filter for shooting through water. I'' post an instructable if it works.
Vulcanator 14 years ago
world_domination 14 years ago
firefighter1333 14 years ago
