Disassembling a Western Digital My Book
298,401
33
48
Introduction: Disassembling a Western Digital My Book
I will demonstrate how to disassemble a My Book using a new 500gb My Book.
Step 1: Removing the Cover
To remove the cover of the My Book, you will need a flathead screwdriver. I also used razor blades, but they can be replaced or omitted if you would like to do it differently.
First, use a flathead screwdriver to pry the mesh away from the cover (do not try to lift the cover up, you will just break things). Start to pry in the middle of the book and you should see two plastic snaps lift up, I put a razor blade between the snaps to prevent them from locking in again. Do this to both sides.
Second, begin to pry the binding area of the book away from the mesh. Pry in small amounts, alternating from one end to the other. When there is enough of the gap, you will be able to slide the cover off of the mesh with your hands.
Step 2: Remove the Hard Drive
For this step, you will need a phillips screwdriver (any size that can handle the case screws in a computer).
First, remove the plastic led extender (I don't know what this is really called, but it redirects the light to the front of the book).
Second, use your hands to lift up the front of the metal insides. Lift the front up until it is high enough to pull the back out of the mesh.
Third, remove the two screws holding the sata controller in place. Then slide the sata controller down to remove it.
Fourth, remove the four screws holding the hard drive in place and remove the hard drive.
Now the enclosure is fully taken apart. If you decide to put it back together, just follow the steps in the reverse order. There is nothing special you need to know about rebuilding it.
Be the First to Share
    • Build a Tool Contest
    • Pets Challenge
      Pets Challenge
    • Fabric Challenge
      Fabric Challenge
    48 Comments
    eddie.hart32
    eddie.hart32
    Tip 2 years ago
    For anyone wanting to know this in 2019, you cannot read or write to the HDD from outside of the enclosure, unless you wipe it. This is because the HDD and filesystem are encrypted against a key stored on the enclosure PCB.
    Thanks
    Eddie
    3l4c1ng
    3l4c1ng
    Reply 11 months ago
    Not necessarily I'm assuming. I tried this on my 1 TB model which happened to have a WD green in it and put it in a different enclosure, can access my files just fine.
    capn
    capn
    11 years ago on Introduction
    Can you remove the drive from the mybook and place it inside a computer?
    pezmanlou
    pezmanlou
    Reply 11 years ago on Introduction
    Yeah, it's just a regular hard drive inside the enclosure. Nothing exotic
    eddie.hart32
    eddie.hart32
    Reply 2 years ago
    I know this is old, but for anyone wanting to know this in 2019 - no. You cannot read or write to the HDD from outside of the enclosure, unless you wipe it. This is because the HDD and filesystem are encrypted against a key stored on the enclosure PCB.
    Thanks
    Eddie
    alan.e.james
    alan.e.james
    3 years ago
    The traditional name for the "LED Extender" is "Light Guide"
    JeffreyMCollins
    JeffreyMCollins
    5 years ago
    New ones have screws at the top and bottom. Much easier to take apart.
    overthetop123
    overthetop123
    5 years ago
    No prying needed. There are two tabs you need to depress with a philips screwdriver and the case slides off.
    JamesD267
    JamesD267
    Reply 5 years ago
    Where are these tabs? Can you reply with photos?
    nshootz
    nshootz
    8 years ago on Introduction
    I got this thing apart and put a 3TB drive in there. I had to first format the drive in my computer, but it's working great now!
    lilidondon
    lilidondon
    Thank you! I recovered mine perfectly. But there is a small piece which I can't define. Can you tell?
    macformat
    macformat
    hi. looks like the support for lock system, upright from the usb connector, maybe is not necessary for the assambly.
    Shanem21
    Shanem21
    Very good...this helped...hope I can recover it now that I know how it's built.
    Didn't break anything but the expired warranty..;)
    LTadpole
    LTadpole
    11 years ago on Step 2
    Thanks a lot. My wife's computer didn't recognize the drive through USB, Firewire 400, or Firewire 800. Your instructions were easy to follow. Hooked it up to my Newer Tech drive reader thingie, and my wife can now access her files. One question: can anyone give me a hint about why all the interfaces would go bad? Is that common? The drive is probably 3 years old.
    rotven
    rotven
    Fortunately my hard drive is still alive and kicking, but I kinda dropped it (please don't file for hard drive abuse!) a few days ago and since then the LED light has been really weak. I could see by looking inside the case through the top that the LED extender slipped to the left a bit, so I cracked it open and moved it back into place. That LED extender isn't secured very well if you ask me.
    Anyway, thank you very much for this guide!
    pezmanlou
    pezmanlou
    If you have the 1.5TB My Book with a similar looking case, you should be able to disassemble it using the same (or similar) technique that I use in this tutorial. If the case looks drastically different and you are nervous about damaging your hard drive, don't be. You can do a lot of damage (from prying) to the case without touching the hard drive.
    mwade82
    mwade82
    thanks for taking the time to share this, you just saved me a bunch of time, frustration, and probably a broken case
    mrcheaterson
    mrcheaterson
    13 years ago on Introduction
    Excellent for disassembly, but be ready for some damage to the case, as the plastic can't handle much levering. also does not work for a WD 1TB drive
