Introduction: Display Temperature and Humidity on Website and OLED(D-duino)
Last class I show the class how to use web control led at D-duino platform.
This class I will show how to use D-duino display temperature and humidity at the same time. D-duino will restart automatically every several seconds. So you can see the temperature and humidity directly from OLED. At the same time you can get this data from website.
Step 1: Prepare
Step 2: Code
Then open ESPlorer write 2 files into D-duino:
init.lua
<p>wifi.setmode(wifi.STATION) <br>wifi.sta.config("Your wifi name","Your wifi password") wifi.sta.connect() print("Setting up WIFI...") tmr.alarm(1, 1000, 1, function() if wifi.sta.getip()== nil then print("IP unavaiable, Waiting...") else tmr.stop(1) print("Config done, IP is "..wifi.sta.getip()) dofile("wifidht.lua") end end)</p>
wifidht.lua
<p>pin = 5 -- The pin you connected the DHTXX<br>status, temp, humi, temp_dec, humi_dec = dht.read11(pin) bimb = 1</p><p>function init_OLED(sda,scl,sla) --Set up the u8glib lib i2c.setup(0, sda, scl, i2c.SLOW) disp = u8g.ssd1306_128x64_i2c(sla) disp:setFont(u8g.font_6x10) disp:setFontRefHeightExtendedText() disp:setDefaultForegroundColor() disp:setFontPosTop() end function display() disp:firstPage() repeat if wifi.sta.getip()== nil then disp:drawStr(0,0,"Wait") else disp:drawStr(0,0,wifi.sta.getip()) disp:drawStr(0,12,"WiFi Connected") disp:drawStr(0,24,"Temperature") disp:drawStr(0,36,"Humidity") disp:drawStr(70,24,temp) disp:drawStr(70,36,humi) end until disp:nextPage() == false end init_OLED(1,2,0x3c) display()</p><p>function sendData() dht.read11(pin) srv=net.createServer(net.TCP) srv:listen(80,function(conn) conn:on("receive", function(client,request) local buf = ""; local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP"); if(method == nil)then _, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP"); end local _GET = {} if (vars ~= nil)then for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do _GET[k] = v end end buf = buf.." </p> Hello Dongsen Technology <p>"; buf = buf.." </p>"; buf = buf.." Tempurature<p>"..temp; buf = buf.." </p>Humidity<p>"..humi.."%"; client:send(buf); client:close(); collectgarbage(); conn:close() end) end) end</p><p>tmr.alarm(2, 6000, 1, function() sendData() end )</p>
You can go to my website to find more interesting thing.
Then just restart D-duino check the IP and Temperature and humidity.
Not so hard but very funny!
Question 1 year ago on Step 2
Hi!! do you something similar on Arduino IDE. I'm using a ESP32 wroom D-duino32-v3. trying to display the sensor values on oled. The board doesnt have proper documentation and it is hard to figure out which are SDA and SCL pins. Thank you.
