Diy Hand Sew 5 Minute Sock Heat Pad .
Intro: Diy Hand Sew 5 Minute Sock Heat Pad .
Brrrrrr!!! its freezing outside! This diy hand sewn easy sock heating pad is great for keeping you warm!!.
STEP 1: Step:1 Put the Rice in the Sock.
The first step is to take your sock and put in your cup so its easier to put it in the sock
add about 1 1/2 cup (for a long sock).
STEP 2: Step:2 I Don't Know What This Is.
Pull up the sides and make shore its the amount you want!
STEP 3: Step:3 Make Shore Your Happy With It.
Make shore you like the amount again because you'll probably want to.
STEP 4: Step:4 Lift It It Out of Your Cup.
Lift the sock out of your cup.
STEP 5: Step:5 Pinch.
Pinch the top of the sock.
STEP 6: Step:6 Lay Your Sock on Your Surface.
lay your sock down and and take your needle and thread and start to sew.
STEP 7: Step:7 Pull Tight.
Pull your thread tight.
STEP 8: Step:8 Knot Your Sock.
Knot your sock (double knot).
STEP 9: Step:9 Cut Your Access.
Cut your access thread.
STEP 10: Step:10 Knot the Top.
Double knot the top of your sock.
