Introduction: Diy Kraft Paper Basket
Hello Friends. I made a basket that you can easily make from kraft paper.
Kraft paper, Glue gun, Scissors.
Step 1:
I folded the kraft paper for easy cutting. I cut it 5 cm wide. So I made long strips 5 cm wide.
Step 2:
I attached the ends of 3 paper strips. And I braided it like a hair braid.
Step 3:
To make a long braid, you can apply glue to the ends of the paper strips and add new strips. You can knit long braids this way.
Step 4:
I'm going to make a small basket. You can make a braid of any length from a ribbon. Don't worry if the braid strip is small, you can always add new paper strips and weave, make a long braid strip without cutting it.
Step 5:
To make the basket, I start from the bottom first. I used an old flower pot as an example. I glued the braid strips in a round shape with glue.
Step 6:
I made a circle as wide as the bottom of the flower pot. Without cutting the paper strip, I started wrapping it around the flower pot. I applied glue in each row.
Step 7:
Do not apply the glue to the flower pot, apply it to the previous strip of paper. Thus, you can remove the flower pot from the basket whenever you want.
Step 8:
I cut 2 small pieces from the paper strip. I glued these strips to the last row of the basket before I made the last row of the basket. Then I did the last row of the basket.
Step 9:
Since I don't stick the flower pot to the basket, I can take it out whenever I want. If you want a long-lasting product, you can apply spray varnish all over the basket.
Step 10:
Kraft paper basket is ready. You can decorate your room and pots by making them in different sizes.
Step 11:
If you want to watch all this content as a video, you can see all the details in this video.
