Diy Lab Power Supply
Intro: Diy Lab Power Supply
this is lab bench power supply
i use atx power supply as main componet
STEP 1: Component You Need
- atx power supply(i use 450w)
- banana connectors
- switch
- leds
- wires(use thickness as per current requirement)
- wood
- and some basic componet
STEP 2: Make Wood Box
make wood box and connect screws cable clamp
STEP 3: Connect Atx Power Supply
put atx power supply in wood box and connect wire to screws cable clamp
the wire connect according to pin map
STEP 4: Diagram of Power Supply
connect all think together as per diagram
and connect all think together on front panel
STEP 5: Make Variable Output
- now make variable output for variable output i use dc-dc converter with variable voltage and current limit .
- it can output 1.3v to 27v and 3A max
- connect all componet as per diagram
dc- dc converterhttps://www.aliexpress.com/item/DC-DC-Step-Up-Down...
12 Comments
saadland 6 years ago
Hi, I've ordered the same Voltmètre Ampèremètre but I dont understand how to connected it cause there is 2 groups of wire, 2 red and 2 black. and 1 yellow, not blue...
which group should be conncted to the module DC converter?? the group with the yellow or without??
when I check the pic by the manucfacturer it is very different and I m lost......
and you please help me to connect it
Thx
EE MAKER LAB 5 years ago
it may be change in color code as per manufacture change so go ahead with the manufacturer's design and try that
saadland 5 years ago
I finally figured out how to connect the Voltmeter
I could not connect 2 pots like you did, and I went with one pot, it is anough precise for me...
EE MAKER LAB 6 years ago
i use 2 pot for voltage and 2 pot for current that give me small change in voltage and current value
no without load resistor it gives me proper out put but now i connect load resistor for safety
gm280 6 years ago
Oh yea, those old ATX power supplies had some pretty stout current capabilities. And they would make a really nice shop power supply. Thumbs Up!
Tech Hunt 6 years ago
