Introduction: Diy Magic Wand | Good Way to Prank Someone
About: Innovative Projects, Diy's, Life Hacks
Did you ever want to become a wizard?
Don't you lie to me. I know you have tried to move objects with your mind.
How did that work out for you?
Just as I thought :)
In this Instructable, we'll have a look at a way to make a Magic Wand.
Maybe it will not do real magic, but your victims don't have to know that.
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1:
I got 2 stainless steel chopsticks.
Even though they look the same, one was a little bit longer and thicker.
I cut them both in half.
Step 2:
Then I sanded the bottom.
Step 3:
I made a few holes in the thickest chopstick's bottom.
Step 4:
After putting some glue on neodymium magnets, I put them in the other chopstick.
Step 5:
Then I glued a piece of plastic to the other side of the magnet.
(so the drill bit we'll use does not stick to the magnet)
Step 6:
I cut a shot from the cap and put it onto a drill bit.
Now put the drill bit inside of the wand and close it.
Step 7:
That's it!
Our magic Wand is ready!
You can do 2 things with it.
1. Make a mini explosion + smoke
2. Put a laptop to sleep.
With a quick motion of your hand, you can trigger a mini explosion with smoke (just like a cap gun)
With the other side of the wand, you can put a laptop to sleep (great for a prank)
It works because of the magnetic switch in your laptop.
I encourage you to watch the video as I think it will be easier to understand the way it works.
