Introduction: Diy Mandalorian Blaster
Today I will be showing you guys how to build mandalorian pistol
Paper/cardstock/cardboard
Step 1: Shape
Start off by drawing the desired shape of your weapon. I am making a mandalorian suit so I decided to do the mandalorian blaster. Draw this on paper. Make sure to include all the detail you want because we will be cutting it out throughout the build
Step 2: Cut
Cut out the outline of your blaster. You will need to make sure you are cutting your line as straight as possible. This will affect your final drawing
Step 3: Trace
Trace out the blaster outline on cardstock or if you want it to be a bit more sturdy you can trace it out on cardboard
Step 4: Cut
Cut out your design you just traced out. Make sure you are as even as possible
Step 5: Filler
Add about half an inch of filler around the border so it is more comfortable in your hand
Step 6: Cut
Head back to your template and cut out the handle part of your blaster and the side of your blaster
Step 7: Trace
Trace this on some grey card stock and cut it out
Step 8: Color
Before adding the grey sidings color the entire blaster black. I colored mine with a sharpie
Step 9: Glue
Glue all your pieces together and there you go. You have a mandalorian blaster. Now go and blast some diplomats because you just joined death watch
