Diy Tape Measure Yagi Antenna for Ham Radio
Intro: Diy Tape Measure Yagi Antenna for Ham Radio
Today we are going to build a Yagi antenna designed for 2 meter and 70 cm ham radio bands. It can be used to communicate with amature radio satellites or to assist in getting into that repeater that is just a little to far away.
I am currently attending Terre Hill Mennonite High School
STEP 1: Choosing Dimensions
For my dimensions I borrowed from KB9VBR's project. I also used an online calculator. The 2 meter side of my antenna is optimized for 145mhz, and the 70cm side is optimized for 437mhz. Feel free to modify parameters to fit to your design.
STEP 2: Cutting Extrusion
This step can be skipped! The extursion will just be 36 in instead a more concise 24.5 in length. By cutting the length at 24.5 1 inch of exturison will be saved on each side.
STEP 3: Cutting Elements
Using the dimensions you decide upon, cut the elements to the length they need to be. Danger! the cut tape measure can tend to be sharp! Add a piece of tape to the ends to avoid being cut by the sharp tape measure.
STEP 4: Printing Parts
Print the parts and remove support materials. Sand parts smooth.
1x Tripod Bracket
2x Driven Element Base
2x Driven Element Clamp
6x Normal Element Base
6x Normal Element Clamp
STEP 5: Adding Tape to the Element Brackets
I placed electrical tape on both sides of the bracket that touches the elements. This provides a rubbery surface for the tape measure to grip against.
STEP 6: Building Tripod Bracket
Put the hot soldering iron tip into the heat set insert and apply force downward untill the heat set insert slips into place. Allow time to cool before touching or applying pressure. Danger insert will be hot afterward
STEP 7: Assembly
Begin by placing the Reflector elements one inch from the end of the extrusion. Asseble the antenna to the dimensions you chose building off of the first reflector. For the 2 meter side leave 1 inch between the driven elements. For the 70cm side leave 1/4 in between the driven elements.
STEP 8: Connecting the Coax
First cut the coax at about the midpoint. Next split the center braid and the outer coating. Solder one to each side of the driven element. Connect the elements with piece of 22awg wire. (hairpin match) Tape up connections to tiddy up the build.
STEP 9: Tuning the Antenna
This step will not be possible without an swr meter!
It is recommended to do this in an open area!
Swr tuning:
- Chose a frequency in the middle of the band you plan to tune for.
- Call out on that frequency that you will be performing swr testing.
- Connect the antenna to your radio via the swr meter.
- Turn radio on low power mode (if you are using a high power radio) if you are using a ht with only a few watts it is most likely not nesecary. But for maximum safety It can be done.
- Key the radio
- The best reading possible is 1:1
- To lower the swr:
- Raise the frequency on your tranceiver. Call out and key.
- If the swr is better that means your antenna is resonent above your target frequency.
- To lower the resonent frequency, lengthen the elements at the gap of the driven element.
- If the swr is worse that most likely means your antenna is resonent below your target frequency.
- To raise the resonent frequency of your antenna, bring the elements together at the gap in the driven element.
SWR is only critical for transmiting.
6 Comments
Kyran Burkholder 1 year ago
Mikiah 1 year ago
Curious_One 1 year ago
de K4KCB
Mikiah 1 year ago
t.rohner 1 year ago
Nice instructable. I think i will give it a try.
One thing that seems incorrect. You refer to wavelength 2m/145MHz and 440cm? I think the second wavlength should be 70cm/440MHz
73 de HB9SFG
Mikiah 1 year ago
