Domestically Sustainable Agriculture - Construction, Planting, and Harvesting
Intro: Domestically Sustainable Agriculture - Construction, Planting, and Harvesting
In an effort to reduce future food costs, and create a lasting source of mainly vegetables and some fruits, we decided to invest some time and money into creating a sustainable garden. We all know the taste and experience of a home grown fruit or vegetable, and the satisfaction of enjoying a domestic masterpiece. It is not shipped from a far off land or an agricultural company, but rather it comes straight from the soil in your back yard.
I wanted to show you how we were able to experience this satisfaction, and I hope you can improvise some of my tips and adapt them to your own garden.
I wanted to publish this Instructable in time for the gardening contest, so I will be adding more pictures and information about the remaining crops that I will harvest!
STEP 1: Find Your Plot
Planning is key, because you must know where you are planting, the dimensions of the plot, and plot characteristics to produce the best possible yield.
When choosing your plot, look for:
- Self accessibility (is it easy to get to?)
- Sunlight (at least 5 hours)
- Water accessibility
- Land quality
- Threats (animals, bugs, etc..)
- Ways to reduce costs (along an existing fence will reduce one side of your costs, or along the side of a barn or wall will reduce one side)
STEP 2: Raised Bed Overview
The type of garden we will be building is known as a raised bed garden. Raised bed gardens offer:
The one major disadvantage of building a raised bed garden is that fact that more labor will have to be put in to building it. Depending on the quality of the build, maintenance can be either easy or hard. So, it will be best to make the most sturdy, and supported bed in order to avoid labor as the season moves on. The raised beds can also dry out a little easier, which is why we will instal a green system of a rain barrel to make use of the rain water instead of continual use of well water.
- Excellent drainage of water
- The soil warms up more quickly in a raised bed than a bed in the ground.
- Maintenance is easy and very customizable
- The garden can be made more easily accessible.
STEP 3: Building Your Raised Bed Boxes
Materials to build one box:
Starting with the 4 ft. end pieces, mark a line 1 inch. in. and then trace the other line with the stake. Now drill two holes from the outside, near the top and bottom of this piece. These will be the holes for your screws when you connect this piece of wood to the stake. Do the same to the other side.
Now take your stake and insert the screws into the stake. It should look like Image 9. Now do the same to the other end piece, and your two end pieces will be complete.
Now find your 12 ft. Cyprus pieces. As shown in Image 10, this piece will be placed on the outside of the stake, but on the inside of the end piece. Take two more screws and connect this piece to the plank. Make sure your screws are in a different spot than the screws on the end piece, because you do not want them to collide.
For however many boxes you wish to produce, repeat the process. For our garden, we will be making four of these boxes.
- 12 ft. rough cut Cyprus (2 pieces)
- 4 ft. rough cut Cyprus (2 pieces)
- 2 in. by 2 in. by 3 ft. pine (Cut in half at a 45 degree angle to get 4 pieces)
- 2 in. stainless steel screws (16 for each box)
STEP 4: Garden Layout
It is time to begin laying out your garden. Keep in mind walking space in between your boxes, and accessibility from all areas.
Lay your boxes out on your plot, and choose the measurements by which you want to separate each box. We chose to separate each box by 4ft., and we also chose to have the boxes 4 ft. away from the fence.
Once your boxes are in their places, take flags or any indicator, which outlines the plot for each box.
STEP 5: Prepping the Soil
For our first soil preparations, we decided to cut out the grass in our outlined plots, and then just turn them over to give a good beginning layer of soil. When the grass dies, hopefully there will be some good nutrients in our soil, and that way grass won't be poking through when we begin planting.
So begin by taking an edger, and make an edge around the plot, and then edge sections of the plot. This allows the shovel to go in easier and separate the dirt and everything. Just take your shovel, shove it into the edges, and lift up. You will now be able to just grab the soil and lift it up. Now just place it back into the same position as it was; except this time the grass will be facing down with the dirt facing up.
STEP 6: Building Your Enclosure
Since we decided to expand our enclosure to include a small plot of raspberry bushes, we are going to need to buy some more 6 foot posts. We chose to have posts that were 6 feet above the ground, because we know that deer can jump over 4 foot fencing, and some may be able to jump over 5 foot fencing, so we decided to be safe and purchase 8 foot fencing and place it two feet into the ground.
We bought 8 foot treated pine posts with a 4 by 4 square base. Where you put your posts is your preference, but try to maximize your area without raising costs too much. You can use differential optimization calculus, or you can just try your best in your head. We used the back of our garage to eliminate about 1 full side of posts. We also have two other sides of existing 4 foot fencing (which we will heighten later), so we did not need very many 8 foot posts.
When you are plotting your posts, be sure to make room for gates. We used 2 Galvanized Mesh Gate which was 4 ft. We also had an extra gate which was much longer, so that we can bring a small tractor in. When you are putting your fencing in, just measure the distance of the fence between two of your posts, and then put up some hinges. Step 9 shows you some pictures of the process.
STEP 7: Installing the Wire Fencing
We went to a Tractor Supply store and purchase 6 foot wire fencing. The brand is pictured in the photo below.
You will be rolling it out and nailing it to your posts. Try to give your posts about a day to become sturdy in their dirt. This will make it easier to nail the wire to the posts. Take the U nails and connect them with as much tension as possible. Try your best not to have waves in your fencing.
As you can see in the first picture below, we have wooden planks to keep the posts up. Our enclosure is a little bit hilly, so we just wanted to be safe when we were nailing. As the dirt dries up, we will take these off.
Once you finish one section, just snip it with wire cutters and take the remaining fencing to your next spot.
STEP 8: Installing Your Gates
As I was beginning to describe in step 7, we used 2 Galvanized Mesh Gate which were 4 ft. long. We also had an extra gate which was much longer, so that we can bring a small tractor in. When you are putting your fencing in, just measure the distance of the fence between two of your posts, and then put up some hinges in the post.
Be sure to scrape away some of the grass that may hinder the gate from smoothly opening and closing. Try to build some sort of stopper for the gate as well. Rocks are perfect candidates.
STEP 9: Deer Protection
The deer can jump over 4 feet of fence, so in the area of our garden where we do not have the wire, we built a 2 foot string protection to make the fence 6 feet tall.
The deer will not attempt to jump through this, nor will they be able to jump over it.
We took 2 foot 2 by 2s and drilled two holes in them to stick the string. Nail them into the existing fence uprights, send the string through, and you have deer protection.
STEP 10: Getting Your Topsoil
The topsoil that we used was screened topsoil, which got rid of any roots, or extra junk that may grow in the topsoil. We found that it was cheaper to buy it in bulk, rather than buying it by the bag.
Take a tractor, or a wheel barrow, and just spread a good amount of topsoil over each one of your plots. You can put your boxes in now, or later, but you should have a good outline of where your dirt should go, as a result of turning the grass over.
Put a good amount on each plot, and then place your boxes into their positions. This way you can judge how much more you will need.
STEP 11: Put the Boxes Back In
Now take your boxes and dig them back into their respective plots. It is okay if they are not completely straight, lord knows that ours were not.
Once the boxes are in, spread the topsoil and add more to each box as needed. Fill them up a little more than 3/4 the way up. I would say about 85% filled up. The topsoil will settle a little bit, but this may be your preference.
STEP 12: Plant Your Seeds
Now select the seeds you wish to plant.
We planted lettuce, herbs, peppers, green beans, carrots, potatoes, beets, tomatoes (plant), and some others I think. Read the back of each seed label for the directions on seed depth and distance from each other. Each vegetable is a little different, so it is important to pay attention to where and how you plant the seeds.
Be sure to water them to allow them to germinate, and as the soil dries up, water some more. Pretty straight forward.
I found a great guide for you all to use and it has tons of information for a huge variety of vegetables.
Fedco Seeds Vegetable Chart
July 6th Update: If you do not want a ton of zucchini, you will only need to plant one or two plants. We planted 4 or 5 and have gotten waay more than we needed!
STEP 13: After 3 Weeks
After about 3 weeks, our plants are definitely sprouting. We have them nicely spaced, and they all look healthy. With the onset of summer, it is very important to keep the soil saturated once it looks dry. Keep an eye on the weather report so nature can water your seedlings for you.
As I walked out today, a rabbit ran out of our raspberry bushes. We will have to go purchase some liquid fence, and other repellents to keep them away. The deer have been taken care of, it is time for us to repel wretched Benjamin Rabbit.
We also experienced another issue. Grass chutes are starting to grow in varying spots in the beds. This is a result of mowing around the beds and the seeds are jumping into the beds and growing. We will deal with this by just removing them as they come up, but you can improvise possibly by adding an artificial walkway area between the beds so you won't have to mow.
STEP 14: Our First Harvest!
We have received our first harvest. Our strawberries are beginning to show some great signs! Today we only harvested one strawberry, but there are definitely more coming!
We used it in a great antioxidant smoothie made of mango, blueberries, yogurt, orange juice, milk, and the lone strawberry! Delicious!
The last picture also shows great signs of what I think are our carrots. Everything works great so far, and there are no signs of animals; so we are looking good!
STEP 15: Growth!
Our plants have really been growing vertically and definitely horizontally! The strawberries are the only plants that have produced as of June 15th, but the other ones are soon on their way!
I am just making sure that each plant receives enough water because it is in the direct summer sunlight.
I am excited about the progress!
STEP 16: Our First Casualty
Unfortunately, this morning when I walked out to water the plants, I found a rabbit just sitting in the broccoli, with the broccoli plants completely eaten.
The rabbit and his/her family must have been there last evening and decided to chow down.
Fortunately, that was the only casualty, so today I will purchase some rabbit repellent. Next year we plan on adding some rabbit cages around the plot for extra protection against these critters.
I have researched some options of rabbit repellents, and I have found many results.
Natural
There are also the dry and spray repellents which can be used around the bed. Companies make tons of different types; many quite similar. Some are urine based, others are blood based, and some are smell based. There is "Liquid Fence" which I have heard positive results about, and also "Cridder Ridder." If anyone has any other suggestions, please comment!
We bought a blood based product, which we just spread around the raised beds, but not on the plants. The instructions told us not to. The bottle tells us that it has a potent smell when animals smell it, and also a toxic taste. So, if we continue to see evidence of Peter Rabbit, we will probably try a new product, or one of the natural methods.
UPDATE 6/24 We sprayed some liquid fence on our veggies, and so far we have not seen any traces of rabbits. Keep in mind that your repellent should tell you whether or not you can use it on edible plants.
Natural
- Marigold
- Mothballs
- Human Hair
- Kitty litter
- Garlic
- Lavender
STEP 17: Chard and Baby Lettuce
Today we harvested some swiss chard and some baby lettuce which we planned on using for the night's dinner.
Much to our satisfaction, we had two colors of swiss chard; yellow and red. We harvested a little bit today by cutting at the base of the leave, with the stem and all. It is great when you saute it. First you should rinse it off, just like anything you harvest. Chop up the leaves and if you like; the stem as well. The stem can be added to a salad to add a unique flavor. Once you chop the chard up, pour some olive oil in a pan, and add the chard. It will be slightly sweet, and you can add some salt to taste. it should resemble spinach somewhat.
Our lettuce was not completely grown, but we decided to harvest a little bit of the young lettuce to mix in with some more mature lettuce that we purchased at a farmers market.
STEP 18: Zucchini Tips
I suggest that if you don't want to be eating pounds upon pounds of zucchini every week, then plant only one or two zucchini plants.
We have harvested too much zucchini for one family to consume in a week. My mom is now planning dinners around zucchini!
When it is the size of a cucumber, or a little bigger, it is time to pick. It should be a darker green color, and nothing like the mutant, giant zucchini that is pictured below. We like to soak cut up zucchini in soy sauce, and then sear it in a pan on low heat. We also stuffed it with sausage and other meats. It was delicious. Of course, we began to get tired of all of the zucchini, and began to wish for our other veggies to begin growing.
Run a Google search to find some zucchini recipes. There are zucchini breads, cookies (mmm?) and probably some delicious ideas. You can always give it away to your friends or sell it on the side of the road.
Here are a whole bunch of zucchini recipes!
STEP 19: Our Tomatoes
We have a wide variety of tomatoes growing... Roma, grape, and beef steak. They are all looking very healthy and it looks like we will have a great crop this year.
Make sure you use tomato cages, because they will help keep your plant upright as it starts to get bigger. Keep them well watered, and your crop will be great.
Of course there are thousands of recipes using tomatoes, but my favorite is tomatoes and basil. We cut the fresh ripe tomatoes and top them with basil and fresh mozzarella topped with some olive oil. It is very delicious and a healthy addition to any dinner!
STEP 20: Cucumbers
We also harvested some great cucumbers as well! You can harvest the cucumbers when they a nice green color, and have some nice looking "warts."
Throw them on your salad, mix them with soy sauce and serve, and do what you like with them!
We are just glad to see that we have something other than zucchini this year!
STEP 21: Conclusion
This whole gardening experience has been a learning year, so here are some tips that we are going to be implementing next year to ensure the best crop.
- Get some rabbit barriers to put up around each raised bed. I saw a groundhog this morning (7/8) in our garden, and also some rabbits! I don't trust the spray repellents. It is better to install some physical barriers so that you are positive that nothing will hinder your crop.
- If you don't want to be eating zucchini all summer, just plant one or two crops. Believe me, we planted four or five (we actually pulled some in the beginning of the season) and we have been eating more zucchini than we can handle!
- Put some bird nets over your raspberries. Once the birds were done with our cherry tree, they went straight to the raspberries. Not next year.
- Separate the big plants from the small ones. Put the zucchini and potatoes in different plots than the small plants like the carrots and the strawberries. They just take over. We actually had to trim down our zucchini to give our strawberries some light!
- At the beginning of the season, keep in mind what you will want a lot of. We had more zucchini than we wanted, and less strawberries than we wanted. So we will probably plant more strawberries next year.
- Don't use store brand soil; try compost! You will see a much bigger yield!
- HAVE FUN!
79 Comments
animal lover 9 years ago
Weimar1942 9 years ago
what do you do against slugs, crickets and grasshoppers?
lucianoabcd 10 years ago
Definitely yes, keep big and small plants separately. There are, though, some combinations of big and small that can be beneficial. For example, a lane of tomato plants and lettuce. This is supposed to work in warm climates, with lettuce initially protecting the tomatoes and the other way around when the tomato plants become bigger, that is full summer.
Another purportedly beneficial association is that of cucurbitaceae (watermelon, zucchini, etc) and bean-producing plants, also especially in warm regions. The former protects the soil from the sun, whereas the later helps to fix nitrogen in the soil (thanks to especial root-associated bacteria). The bean plant needs to be kept raised with a stick or something, so a third component in this system could be a corn plant or similar.
Strawberries are much better alone, and in a position where you can daily remove any weeds. But protect them from birds, the bastards pick the best fruits in the best moment of the day, usually when you are not there to scare them away!
a.steidl 10 years ago
freeman21 11 years ago
timsbro2000 12 years ago
DIY-Guy 11 years ago
And now for a programmers joke- ! deer
[The exclaimation point symbol is sometimes called a 'bang' when reading code aloud.]
Totysheep 12 years ago
wirechief 14 years ago
tornadoboy 14 years ago
M F 14 years ago
nkhouri haddad 12 years ago
I tried the liquid fence but no luck, a friend advised to spray plants with hot sauce and it worked on my plants, but I have a lawn that they are intrested in more!
popa27272 12 years ago
gregolma 14 years ago
Buskieboy 14 years ago
kingmotorsport 14 years ago
xenoxx 14 years ago
Doug.
rocklocker 14 years ago
