Double Chocolate and Maple Brownies
Intro: Double Chocolate and Maple Brownies
Dear Readers,
Thank you so much for clicking on this post! I hope you enjoy making and eating this fudgy little brownies as much as I did. They are completely from scratch, and you don't need any chocolate chips (Except as an add in.) The inclusion of chocolate chips is incredibly unnecessary, in fact, cocoa powder helps create the fudgy center I talked about earlier. I will admit that without the chips these are not actually double chocolate brownies.
On your mark!
Get set!
Bake!
-Maya
STEP 1: Prepare
Position an oven rack in the center of the oven, preheat to to 325 degrees F. Line a 8x8 inch square pan with parchment paper OR lightly grease 9 muffin tins. If using muffin tins, place them on a large metal baking sheet.
STEP 2: Melt the Chocolate Mixture
Make a double boiler by filling a saucepan about 2 inches high with water and heating until barely simmering. Turn the heat to low.
Cut the butter into smaller pieces and put it in the medium bowl, add the maple syrup, cacao powder, and salt.
Place the bowl over the saucepan and gently stir the contents until the butter has melted and the maple syrup and cacao powder have mixed*.
Take off the heat and let cool until you can stick your finger in it without getting burnt, about 5 minutes.
*The maple syrup and cacao powder don't bind without oil. Be patient, wait until the butter is mostly melted before mixing.
STEP 3: Add the Vanilla
Gently stir in the vanilla.
STEP 4: Add the Eggs
Add the eggs, one at a time. After you crack the eggs in, break the yolk up with a fork, then stir thoroughly. You do not want any clumps of egg whites floating around in your batter.
STEP 5: Add the Flour
Stir in the flour, little bit at a time. Use a spatula to push runaway chocolate and flour back into the bowl. With these brownies, you want to over stir, it helps the batter get nice and thick. When you can run the spoon through the batter and it takes a minute to fill in the canyon you created, you can stop stirring.
STEP 6: Add the Chocolate Chips
Gently roll the chocolate chips in a small amount of flour before stirring them into the batter.
STEP 7: Bake the Brownies
Spoon the batter into the prepared 8x8 inch square pan OR the 9 muffin tins. Place them in the oven.
If using a 8x8 inch pan, bake for 20-30 minutes.
If you use the muffin tins, as shown in the picture, bake them for about 18-22 minutes.
To check them, stick a toothpick into the center. If the toothpick comes out really gooey, stick them back in for about three more minutes. If the toothpick comes out with a few crumbs on it, their done.
Take them out of the oven and let cool completely, DO NOT skip this part, it is crucial!
Once cool, take them out of the muffin tins, or slice them into about 16 brownies.
Done!
