Double Voltage of Your One AA Battery Device
Intro: Double Voltage of Your One AA Battery Device
A very simple method to get double output voltage within the space of a single AA battery. Useful for strengthen your single battery powered device, eg. flash light, nose hair trimer and etc.
STEP 1: Reason
Sometimes you are not satisfy with the POWER of your single battery powered device, such as your dim tiny flash light, tooth polisher or the MOST common used nose hair trimmer.
For me, I have changed a lot of them but they are all slow even when I use a NEW battery.
Each time I used them I sweared to put TWO batteries inside it someday.
STEP 2: Got the Spirit of the ENELOOP Battery
Got the spirit of the ENELOOP battery today! Why don't we use TWO SMALL batteries with physical adapter?
STEP 3: What You Need in ALL.
This is what you need in ALL:
one AA battery as a ruler;
one 9V battery for giving birth of SMALL batteries :)
tape
marker
knife
pliers or scissors
It will take 5 to 10 minutes to finish it.
tape
marker
knife
pliers or scissors
STEP 4: Giving Birth to Small Batteries
Now let's giving birth to small batteries! Carefully open the case of the 9V battery.
Be sure not to choose the cheap band, some cheap band only have square babies.
DURACELL works fine here in US, you may make a try in other country.
STEP 5: Cut Babies Into Single
Here we got 6 baby batteries and each of them is 1.5V and powerful ENOUGH.
STEP 6: Cut the End As What We Need
Be careful, we are going to cut the linkage metal into what we need.
Flat end short and the other end long;
Please do not just cut it down in equal by scissors.
STEP 7: Hard Core
Here comes the hard core of our DOUBLE battery. We are to put them together and make them as long as the AA battery.
STEP 8: Cut a Bit of Skin of One
Mark the point and cut a bit of skin of one.
STEP 9: Tape Them Together
Tape them together and make sure one battery's end is firmly contact with the other's naked body, that's why we cut the skin before.
Firmly contact please.
STEP 10: You've Done
Tape them with more tape and keep IT at the length of a AA size battery, you've done.
STEP 11: Don't Fall for Its Shape
Man, don't fall for its shape! The positive end is the FLAT one!
STEP 12: Get Ready to USE It
ok, get ready to USE it.
Same length, almost same width, flat as the positive.
STEP 13: LENGTH
You can even fine tunning the length by slightly bentting the ends.
STEP 14: Yes It Works!
Yes, it works here.
STEP 15: Sounds Powerful
sounds powerful and never had this kind of trimming experiance before
STEP 16: For Really Tighten Application
for some really tighten applications like this kind of Maglite flashlight, please shape the baby batteries a little flat BEFORE putting two together.
STEP 17: Keep in Mind
Please keep in mind, other BABY batteries have the FLAT end as the positive.
Good luck on your next hobby DIY!
19 Comments
DWinker 15 years ago
socrateez 15 years ago
Razorsedgeartwork. 6 years ago
he never says he's doubling the voltage of a battery, only doubling the voltage to the unit.
DWinker 6 years ago
Good point! It's been a while since I looked at this, but I was probably looking for voltage doubler circuits and got annoyed when I realized what this was.
Thank you for the correction!
Neselot 7 years ago
y not put the batterys in parralel so u still have the 1.5 volts and u have longer living batterys in the end and put it in an old battery after taking everything out of it.
Antbal0 8 years ago
How to double the voltage of your battery! Use different batteries!
tramsey7 10 years ago
badams2 11 years ago
ossumguywill 14 years ago
gear-guy 14 years ago
james.mcglashan 15 years ago
Hman545 15 years ago
YoChuck 15 years ago
dragonbtv 15 years ago
frollard 15 years ago
pudicobar 15 years ago
