Introduction: Dowel Arrows
These arrows are made for my pvc bow I have an instructible on
Step 1: Supplies
1 dowel rod 69cents Electrical tape/ duct tape Saw Knife
Step 2: Shaft
The dowel makes two arrows. Cut it on half with a hacksaw. Try getting the cleanest cut possible
Step 3: Notch(I Think It's Called That)
Just find the end of the arrow. Cut straight down from the middle with your saw about a centimeter
Step 4: Fletching
Cut a 2 1/2 inch piece of duct tape or electrical tape. Set it parallel to the notch about an inch from the notch. Do it to the other side. Push sides together. Cut out shape of fletching u want on both sides.
Step 5: Tip/head
Next, sharpen the end. Or cut heads out of sheet metal and glue it in place. Sorry I don't have pics. If u sharpen it garden it in fire
Step 6: Finished
Now ur all done. Check out my bow instructible that these arrows r designed for
5 Comments
Tip 4 years ago
You can buy a flights and nock combinations on ebay whick save time and make a more accurate and safer arrow and they just push on and they are made of plastic so cheap you can stock up on them
4 years ago on Introduction
You might consider, that you String wrap or ?? Wrap the ends before cutting..it add's support and durability..
8 years ago on Introduction
What is the diameter of the dowel?
Reply 8 years ago
(I realize this is a bit late but...) from what i understand, most arrows are between 1/4 and 3/8 inch
What is the length of the dowel?
