Introduction: Dreamcast VMU LiPo Upgrade
If you like that piece of retro hardware, but tired of replacing batteries every week - here's the solution!
Step 1: Extra Parts Needed
1) LiPo battery small enough to fit inside, I used 138mAh
2) SparkFun Power Cell - LiPo Charger/Booster
VMU works with minimum of 5V.
3.7v LiPo battery is enough to power VMU, but it'll give you "low power" warnings
so to get it to 5V you can just use a step-up or use charger/booster, I had one around so I went for this option.
Step 2: Free Some Space Inside
To fit everything I had to unscrew and remove metal contacts used for CR2032
Also to clear everything even more I snipped all extra plastic inside and made opening for USB connection.
Step 3: Put PCB and Battery Inside
Don't forger to solder jumper to 5v output
Solder output from Charger/Booster to battery input on VMU
Solder battery to input of Charger/Booster
Don't forget to isolate everything
Step 4: Put Everything Together
After checking that everything isolated and working put it back together and enjoy!
So now you can use your VMU as usual and just recharge a battery over USB.
If you want to take it further it's possible to use power from controller to recharge LiPo in VMU
Possibly I'll try to upgrade it a little bit more in future
3 Comments
5 years ago
Здорово!
А сколько, хоть примерно, VMU работает от такой батареи?
Reply 5 years ago
К сожалению не очень долго. Около суток.
В планах добавить зарядку от геймпада, чтобы аккум в VMU заряжался, пока она в геймпаде.
5 years ago
That's a neat mod :)
