Introduction: Drink Table
Check out the video for more in-depth instructions.
Click here to follow me on Instagram
Step 1: Cutting the Wood
To make this drink table, you will need the following:
(2) 2x4 cut to 28.5 inches for the leg
(5) 2x4 cut to 14 inches for the top
(4) 2x4 cut to 14 inches for the bottom
Step 2: Removing a Thin Layer
If you have a thickness planer, remove a thin layer from both sides to give the wood a smooth surface.
Alternative:
Us a sander to remove the rough surface.
Step 3: Squaring Up the Wood
A typical 2x4 usually has a round over edge. Use a table saw to remove the round edge, creating a flat surface.
Step 4: Notching Out the Feet
1. Set up the feet. Then place the legs toward the back, centered on the feet. Trace out the feet.
2. Cut out that section.
Step 5: Joining the Leg
The two pieces of wood measuring 28.5-inches long make up the leg. Join the two pieces together using biscuit and wood glue. Wood dowels would work, too.
Step 6: Attach the Leg
1. Now, glue and attach the notched-out wood.
2. Countersink two holes, and install (2) 3-inch screws.
3. Install the final three 2x4s using biscuit or dowels.
Step 7: Attaching the Top
The top will have a bit of an overhang. So, center the leg into one of the 2x4s.
I used the drill press to drill out the hole. Then, used a chisel to square out the hole.
This should be a tight fit. Glue and screw in place.
Use biscuit or dowels to secure. I also added (2 to 3) 3-inch screws for extra support (for each 2x4).
The last 2x4 was only secured with biscuit and glue. (No screws).
Step 8: Sand and Paint
Sand and round the edge. Then, paint.
Step 9: Stain
1. Apply stain. I used Minwax Gel Stain " Hickory" http://amzn.to/1OK9gVm
2. Remove stain with a cloth.
Step 10: Protection
1. Apply Polyurethane with a brush.
2. Four hours later, sand with 400 sandpaper.
3. Apply one final coat of Polyurethane.
Step 11: Pad
Install 4 felt pads to keep the wood off the floor.
Done!!!
Fourth Prize in the
Outside Contest 2016
1 Person Made This Project!
- cristy1717 made it!
11 Comments
2 years ago on Introduction
Loved your build so much I made my own. Thank you for the inspiration! I love your building videos. Stay safe.
6 years ago
Love tables in this style! This is great :)
Reply 5 years ago
Thank you :)
6 years ago
Very nice project but the outstanding video is the show piece here. Thank you for taking the large amount of time, care and thinking it obviously took to make and edit. IMHO I'd like to see you share an Instructable on how you organize, light, film, and edit video. The thinking thru, organizational, and structural work you've done is really interesting to me and I think would be a terrific contribution to others. EXCELLENT work!!! Truly a model for others to follow.
Reply 5 years ago
Thank you I will definitely consider it.
6 years ago
You've made a super little table here, congratulations!
Reply 5 years ago
Thank you.
6 years ago
Great job man. I really like this. I need to explore that biscuit you are using during the project
Reply 5 years ago
Thank you. Yep biscuit are fun
6 years ago
will be trying this..brilliant.
6 years ago
Awesome project! Nice to see you're on Instructables too! (if I'm not mistaken)
