Drum Beats in Audacity
Intro: Drum Beats in Audacity
This Instructable will show you how to generate a sequence of drum beats in Audacity which can be mixed with other instruments.
STEP 1: What You Will Need
You will need:
A computer capable of running Audacity (Linux, Windows, or Mac)
Audacity
Audio Selection Sequencer 2 Audacity Plug-in (Download from http://wiki.audacityteam.org/wiki/Download_Nyquist_Plug-ins)
A set of drum sounds (Included as ZIP file with this Instructable)
Audacity
STEP 2: Installing
Make sure Audacity is installed. Then extract seq2.zip which you have downloaded from (http://wiki.audacityteam.org/wiki/Download_Nyquist_Plug-ins) and copy seq2.ny into /usr/share/audacity/plug-ins/ if you use Linux
OR
C:/Program Files/Audacity/Plug-Ins if you use Windows
Extract 17-29_TicTacShutUp_Studio_Drums_1.zip . It does not matter where the drum sound files are placed as long as you can remember where they are.
OR
STEP 3: Import Drums
Open Audacity. Under Effect... Plugins 1 to ? "Audio Selection Sequencer Two" should appear. Next, Import the drums you would like to use by clicking on File...Import...Audio. Each drum should be a different layer/track. You may wish to label the tracks by clicking on the down arrow beside the track, then name, then type the name of the drum (eg. bass drum) All tracks should be mono. Double click the track to select it and then click Tracks...Stereo Track to mono. Do this with all the tracks. Remove any unwanted audio by highlighting and then pressing Delete but be careful not to remove too much.
TIP:Be safe, save often.
STEP 4: Sequence
Double-click to select the first drum track. Then go to Effect... Plugins 1 to ? ...Audio Selection Sequencer Two. Enter a tempo. Beats per sequence should be "4". Overall Transpose Value, then for successive measures should be "0". Sequences to generate should be "1". Type in the semi-tone volume pan (SVP)values, these will be the drum pattern.
(0 1 0) is a hit
() is a rest
therefore "(0 1 0) (0 1 0) (0 1 0) (0 1 0)" is constant hitting
Create patterns for the other drum layers.
STEP 5: Finishing Up
Adjust the volume levels of the individual tracks if needed by clicking on Effect...Amplify. Negative amplification will lower volume levels. Positive amplification levels will raise volume levels. Avoid clipping. That's it, have fun!
I have attached MP3, OGG and Audacity versions of a drum sequence I have generated. The OGG version will play directly in Firefox.
15 Comments
JossBeaumont17 7 years ago
Hi, Thanks for the tutorial.
I have a question I did all the
steps you mentionned but when I go into effect I simply cannot see the
"Plugin 1" entry, nor can I see the "Audio selection sequencer". Do you
know what could be the problem ?
mysteradio 2 years ago
DNB ALL DAY MAKER 3 years ago
MikeW271 7 years ago
I've Just started with this, so I'm sure with a little more fooling around, I'll figure it out, but I can't seem to get a sequence that's any longer than like 45 seconds. Is there a way to make them longer, or do I have to string a few of them together?
GrangromD 8 years ago
In Ubuntu (Linux), the default plugins directly has actually changed to /usr/share/audacity/plugins
Also, thanks for the tutorial but I'm not sure if I'll end up using this because it's time consuming to edit each drum's sequence individually. Might be easier to use a separate drum machine program and just record the output.
CareyD1 8 years ago
How do you open the kit sounds in audacity?
instructables_user_4783 8 years ago
You first need to extract the .wav files from the .zip file. Then to import a wave file into Audacity run File-->Import-->Audio and select the drum sample which you wish to use. Choose the make a copy (safest) option.
RandyH3 9 years ago
I'm confused. I'm no expert on this sort of stuff, but can you be more specific with this section? I have windows, and the part where you say to "copy seq2.zip into C:/Program Files......" is throwing me off big time. Haven't got to where I can see Audio Sequencer 2 on Audacity yet. What am I doing wrong? Thanks.
OR
Frances75 9 years ago
thanks....is quite useful.....
instructables_user_4783 9 years ago
Okay, 17-29_TicTacShutUp_Studio_Drums_1.zip contains the .wav files for the drum beats. Once this zip file is extracted, the wav files can be imported into audacity and sequenced. seq2.ny must be placed in the audacity plugins directory. C:/Program Files/Audacity/Plug-Ins .Audacity will automatically load these plugins on startup.http://wiki.audacityteam.org/wiki/Download_Nyquist_Plug-ins also suggests that these plugins can be placed in C:\Program Files (x86)\Audacity. on 64-bit Windows. So, just copy and paste seq2.ny into that directory.
RandyH3 9 years ago
OR
RandyH3 9 years ago
OR
JaniThor 9 years ago
does this work on Windows 8?
androidlove 12 years ago
instructables_user_4783 12 years ago
