Dtv Antennas I Have Tried or Will Try.
Intro: Dtv Antennas I Have Tried or Will Try.
Some of the home made OTA DTV (over the air digital television) antennas I have tried (or going to try). I will add additional pictures as I test them.. Since your mileage may very I will not rate them. One was even just a telephone wire cable (not pictured yet). If you have any suggestions for antennas, please let me know.
More: https://www.instructables.com/id/Dtv-Antennas-I-have-tried-or-will-try-part-II/ Latest antennas here.
There are lots of things to test. Vertical or horizontal position, whether they were meant to be uni-directional or omnidirectional, how populated are the stations are in your area, whether the stations are all in on major direction or spread out in a circle from you, and lastly what kind of signal booster are you using or not using.
Interesting links:
http://n4ywn.eagle3.net/docs/antenna-calc.html
TVFool.com
http://www.titantv.com/
Interesting links:
TVFool.com
16 Comments
HoldOnTight 9 years ago
Link for finding tv signals is tvfool.com (no "s") and for FM signals, use the link in that home page as well.
enjoy better reception
Computothought 9 years ago
Thanx for catching the typo. Have not looked at this instructable in forever. Generally, if you have a good non-drectional antenna and tuner. Getting the stations is not so critical. We get over 100 stations.
davijordan 10 years ago
fpoole 11 years ago
The telephone wire antenna you made has an impedance of 125 ohms and is close enough to the 75 ohm cable impedance that mismatch is negligable.
Both CAT5 and telephone wire have the same impedance of 125 ohsms.
Lamp cord and Romax wire are 75 ohms on the other hand so a better match
Shartmaster 12 years ago
Computothought 12 years ago
66tbird 13 years ago
Anyways, Computohought, your little number is a great example of a good antenna. With a little math you can taper and space to fine tune the elements to catch the 450-650 Mhz using some harmonics really well, A quality amp well help if the signal is steady but low. If it's a drifting thing I've not had much luck on the amp side using an indoor antenna.
Computothought 13 years ago
One more I've setup on a home where outdoor setups were permitted, (HOA thing). We turned the small element array on its side. Mounted two more identical ones also vertically but at different angles to point a different mountains or cities. With an amp he does really well pushing the signals from four major cities to four tv's. Over 70 channels with dups but different times.
After it was all done I told him about Hulu,, haha
RedneckEngineer 13 years ago
dosadi 13 years ago
w2sqr 13 years ago
