Introduction: Duct Tape Make-up/Toilet Bag for Her and Him
I travel a lot for my job and I have had a lot of troubles at boarders with my toilet bag. After many attempts I managed to build a long lasting (most of the plastic bags couldn't make more than one way) bag using transparent tape. I adapted this design with coloured duct tape to make it funnier.
I would like to share it with you today.
What you will need:
- A freezing bag,
- Duct tape, best of different sizes and colours,
- Utility knife and/or X-facto knife,
- Ruler
- A flat surface as a cutting mat
Let's build it!
If you like this I'ble, like it and vote!
Step 1: Setting Your Bag
First we will cut the zipper from the the freezing bag.
Take the freezing bag and cut the zipper using the ruler and a knife. You would then have 2 parts for the zipper.
Take one of your zipper parts and position it straight on the cutting mat.
Glue a strip of duct tape, side to side of the zipper. Then glue as much other bands as needed with a little overlap. This will set the width and the height of your pouch. Flip the zipper and glue it in a little hem.
Flip the assembly and glue other bands of duct tape on the back (sticky) of your mounting.
You should end with a two-sided duct tape folio.
Repeat the instructions with the other part of the zipper.
Step 2: Make It a Bag
Take your two folios and assemble them using the zipper.
Position each part carefully in order to obtain the desired size/effect.
Using your ruler and utility knife, remove all extra tape.
Tape a band of duct tape on the bottom of one folio, allowing a part to be flipped and glued on the other folio, creating a connection between the two. Remove extra duct tape and do the same with the sides of your bag.
Once done... you're done. You have a bag.
Step 3: Decoration
If your bag is now finished, it is much better and more beautiful with a little decorating effort.
I have used some masking tapes of different sizes and colours to decorate my 2 bags. I used the ruler to regularly positions the bands.
Et voilà!
Thanks for reading.
