Duct Tape Wallet
9,130
158
14
Introduction: Duct Tape Wallet
When everything fails, duct tape will fix it, no matter what. And if it still fails, then you haven’t used enough duct tape. A lot of people don’t know that duct tape is sometimes also used for other purposes, so let’s turn a bunch of duct tape strips into a fully functional wallet that will last you years.
This is an easy and fun project to make, even if you have never worked with this kind of material before.
Step 1: Gather Your Materials
You will need:
- two different colored/patterned rolls of duct tape
- scissors (or cutting knife)
- ruler (or other measuring device)
- hard, clean surface to work on
Step 2: Decide on Your Primary and Secondary Color
I have one roll of blue duct tape and a roll of duct tape with a flower pattern. I decided to use the plain blue as my primary colour and the flower pattern as my secondary colour.
Step 3: Cut Three Strips of Your Primary Coloured Duct Tape
Each strip should be 18 cm long.
You can also make these strips longer or shorter, depending on which currency you will want to fit into your wallet.
Arrange the three strips to make a sheet of duct tape, as shown in the picture.
Step 4: Cut Three More Strips of Your Primary Coloured Duct Tape
Arrange them into another sheet of duct tape and stick both sheets together (so that the adhesive sides cover each other).
Step 5: Cut One Strip of Your Secondary Coloured Duct Tape
This strip should be 18 cm long.
Cut this strip in half lengthwise, so you end up with two, thinner, strips of duct tape that are both the same length.
Tape one of the thin strips onto one end of your first, big, sheet of duct tape and the other thin strip onto the other end of your first sheet of duct tape. This will help make a smooth, clean edge. If there is any excess duct tape that is going over the edges, cut it off.
Step 6: Fold Your Sheet of Duct Tape in Half
Fold it in half so that the clean edges cover each other.
Step 7: Cut One Strip of Your Secondary Coloured Duct Tape
This strip should be 7 cm long, or the height of your folded sheet of duct tape.
Tape one of the thin strips onto one end of your folded sheet of duct tape and the other thin strip onto the other end of your folded sheet of duct tape. This will create the pocket where you can put in the banknotes.
Step 8: Fold Your Sheet of Duct Tape in Half
You may stop here if you wish to, but we are still going to add an inside pocket.
Step 9: Cut Two Strips of Your Primary Coloured Duct Tape
Each strip should be 9 cm long, or half of whatever length you made your first sheet of duct tape.
Stick both strips together, so that the adhesive sides cover each other.
Step 10: Cut One Strip of Your Secondary Coloured Duct Tape
This strip should be 9 cm long, or half of whatever length you made your first sheet of duct tape.
Lay one of the strips aside.
Tape the other strip onto the top edge of the smaller sheet of duct tape.
Step 11: Use the Left Over Strip of Duct Tape to Tape the Bottom of Your Inside Pocket in Place
Use the duct tape strip you just lied aside to tape the bottom of your inside pocket in place.
Step 12: Cut One Strip of Your Secondary Coloured Duct Tape
Cut this strip in half lengthwise, so you end up with two, thinner, strips of duct tape.
Use these strips to tape the sides of your inside pocket in place.
2 People Made This Project!
  • Make It Bridge
    Make It Bridge
  • Big and Small Contest
  • Game Design: Student Design Challenge
14 Comments
amberrayh
amberrayh
7 years ago on Introduction
A very simple wallet. I like the colors and pattern. Thanks for sharing!
Mja1520
Mja1520
You're welcome for sharing and thank you for your nice comment :D
Zobug
Zobug
7 years ago
That is soooooo cute
VictoriaC94
VictoriaC94
6 years ago
I was going to make this, but I can't find my duct tape.
AzJavi
AzJavi
6 years ago
awesome.
crystal78987
crystal78987
7 years ago
I made a wallet like that. I probably wasted half the roll of duct tape, but i did it. Then i made another wallet that was more complex. They both look awesome! I really like the colors U used too. I used purple and teal zebra stripes.
dnuge6
dnuge6
thank you. mine turned out really well but i decided to add another inside pocket.
Jmintuck1912
Jmintuck1912
7 years ago
I love it ! I'm so doing it.
