Introduction: Duffel Button
The following information is a single lesson in a larger Tinkercad project. Check out this and more projects on Tinkercad.
In this lessson you will make a duffel button. This is similar to to the basic button, but uses a longer shape to create the button. Let's get started!
- Drag a Box shape to the workplane.
Step 1:
- Scale it smaller to a height of 8mm and a size of 8mm x 20mm.
Step 2:
- Drag a Round Roof shape to the workplane.
Step 3:
- This shape will be added to the end of the box shape.
- Scale it smaller to a height of 4mm and a size of 8mm x 8mm.
Step 4:
- Rotate the shape and place it at the end of the box shape.
Step 5:
- Copy and paste the Round Roof shape and rotate it so it will fit on the other end of the Box shape.
- Use the area highlighted in orange as a guide.
Step 6:
- Drag a Cylinder to the workplane and set it to be a hole.
Step 7:
- Scale it smaller to a size of 3mm x 3mm.
- Copy and paste the cylinder.
- Rotate and move them to the areas highlighted in orange.
Step 8:
- Select all the shapes and group them into a single object by clicking the group button on the menu bar.
Step 9:
Congratulations! You made it!
