EM-483 Specifications
Intro: EM-483 Specifications
I have seen many people, including myself looking for technical specification for this particular stepper motor stripped from old printers but nothing seems to show up so I decided to share with you some characteristics and the recommended operating parameters I have discovered:
Type: Bipolar Stepper Motor
Supply: 5-6V
Coil Resistance: ~3.6 omhs
Max Current: ~1.4A
Operating frequency: 500Hz
Maximum speed: 150 rot/min
STEP 1: Driving Algorithm for the Stepper Motor
I have set the operating frequency at 500Hz because if you go higher the electromagnetic inertia of the of the coils will make it so there is a high danger for the motor to skip steps if put under load. It also gives you nice round numbers when doing the math.
As shown in the picture the algorithm requires the following 8 step sequence applied to both coils for it to work properly. Each sequence takes 8ms and moves the motor 4 steps (7.2 degrees).
Because the stepper motor has 1.8 degree step it takes 200 steps to make a full rotation, thus we can calculate that a full rotation will be done in 400ms.
And from that you can get the 150rot/min maximum speed.
The 500Hz operating frequency is derived from the fact that you have 4ms pulses for each step (3ms active 1ms pause) but you have 2 coils, so you get a step each 2ms.
1000ms/2ms=500Hz
Correct me if I'm wrong.
14 Comments
mariano2202ze 2 years ago
AlbertoP6 4 years ago
I have Arduino Uno, CNC Shield V3 and DR8825 drivers (how much Vref voltage needs?)
Thanks in advance.
En la mayorÃa de casos se utiliza una R100, de todas formas fijate en el driver cerca del integrado hay una resistencia smd, ese es el valor que tenes que utilizar
MADM1 4 years ago
Almost_Divorced 3 years ago
2 articles on that:
https://www.instructables.com/Drive-a-Stepper-Moto...
https://www.instructables.com/Control-DC-and-stepp...
mario pardo 4 years ago
omnibot 7 years ago
Adding my finding;
200 steps/ 1 rotation
omnibot 7 years ago
Also .. had no problems running it on 12 volts.
JohnC1139 6 years ago
colin55 6 years ago
The waveform on coil B during the 8th transition should have a line (a return) to the the 0v rail to "close-off" (finish) the actual waveform.
StratosB 8 years ago
I extracted the same bipolar stepper motor from an epson printer and want to drive it with L293D.
I would expect your waveform to have values between positive and zero. Why do you include negative values?
Thank you
amberrayh 8 years ago
This is very helpful. Thank you for sharing!
Kuuran 8 years ago
Tumbleweed. 8 years ago
thanks for pointing that out, I have updated the image.
