The Mini ZT456 Gun(Bunduk's True Trigger)(small Easy 2 Build)
Intro: The Mini ZT456 Gun(Bunduk's True Trigger)(small Easy 2 Build)
If you have a few pieces and /or aren't an experienced knex builder, this is the gun for you. This Instructable has very clear instructions. It has a true trigger. adding a mag is easy, but like I said, this is a noob gun. I was inspired by BUNDUK so give him/her some credit. thanks, and enjoy!
p.s
(adding a laser is fun too. watch my vid with the laser.)hi
it isnt difficult
p.s
it isnt difficult
STEP 1: The BARRELL
it is quite simple. peice count:
Orange connectors:1
Red connectors:8
Light grey2 connectors:2
rod/connecor black peice 2
yellow rods:2
White/grey little rods:1
Black/green toney rod:1
Get your two yellow rods. add a red connector in between the two rods. add two more red connectors. get the orange connector and add a connector/rod peice to one end, and the green/black rod to the other.gather the white/grey rod and 2 light grey connectors. add the two grey connectors to the white/grey rod. add 5 more red connectors.AND I FORGOT TO MENTION THIS. ADD ANOTHER ROD/CONNECOTR BLACK PEICE PARRALEL TO WHERE THE BLOCK THINGY IS. If this wasnt clear enough, you need a new brain
Orange connectors:1
Red connectors:8
yellow rods:2
STEP 2: The Handle Dun Dun Dun!
this is the handle. its got a good grip. please follow.
Peice Check:
2 blue rods
4 green rods
two white rods
4 dark grey 1 connectors
6 yellow cresent connectors
pic 1: get 3 yellow connecotrs, 2 green rods and 1 white rod.
make this shape as seen below.
After you have made this shape, make another one.
join them with 2 blue rods in the places shown.
pic 2: add the grey rods as shown.
Peice Check:
2 blue rods
4 green rods
two white rods
STEP 3: The Firing Pin. (the Easiest Step
Do I reli have to explain myself? make this
im nto going to bother put a peice count thing.
STEP 4: The Trigger System
1 axle peice( the baige/goldy broen thing next to the spacers
4 spacers.
1 yellow rod.
1 black thingy ma bob.
1 light grey connector
2 green connectors
1 blue rod
1 dark grey connector
1 white/grey rod
pic 1: make the following.
pic 2: make the following.
pic 3: join the two recent made parts together
pic 4: join the dark grey connector that is on the HANDLE to the side of the BLUE rod that has no other epices on it(the blue rod that is on the TRIGGER) This step is a little hard, but use your brain and ull get it XD or pm me or w/e
4 spacers.
1 yellow rod.
2 green connectors
1 blue rod
1 white/grey rod
STEP 5: Extending the Barrell(optional But Makes Puting on the Bands Easier)
the black peice in the middle isnt needed. i did not have enough dark grey connectors. its :
2 orange connectors
1 yellow rod
5 dark grey connectors
(Another easy step.)
btw, who has played WARROCK (www.warrock.net)
2 orange connectors
1 yellow rod
STEP 6: Putting Everything Together(medium Level of Difficulty for Noobs)
In this step you be adding things together.
pic 1: add the barrel and the handle/trigger system together
(note that the bit on the end of the blocker should be underneath the long______________ part that is connected to the trigger
(pulling the trigger moves the long thing down, which pushes the the bottom of the blocker, ehich releases the firing pin which his
your bullet and BAM yo mama is dead!!
pic 2: add the firing pin.(IF you have problems doing this you need mental help.)
pic 3: add the extended barrel to the barrel.
pic 4 and 5. add the rubber band from the end of the purple connector to then end of the extended barrel or somewhere else if you didnt make the extended barrel.
STEP 7: Loading and Firing
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/bqmz7XE2_8E"> </param> <embed src="http://www.youtube.com/v/bqmz7XE2_8E" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
i have put a youtube movie of this, but slightly bigger, with a tiny magazine, and a laser. see how accurate and powerful this
babe is!!
http://uk.youtube.com/watch?v=rHR-Ibpjfw0
babe is!!
63 Comments
ryry2011 13 years ago
a10lover 13 years ago
jackerboy 13 years ago
DeadLocked 14 years ago
ash1494 14 years ago
Blackonyx2234 14 years ago
Tom Buckey 15 years ago
tahirhh 15 years ago
https://www.instructables.com/id/Mod_the_Mini_ZT456_gun_into_airsoft_pistol/
ash1494 16 years ago
I_am_Canadian 16 years ago
jli1 16 years ago
how the **** do you add a mag! (that holds at least 6 rounds)
crestind 16 years ago
gunnerguy 16 years ago
bunduk 16 years ago
