ENS160 + AHT21 Sensor for Arduino
Intro: ENS160 + AHT21 Sensor for Arduino
Interface an ESP 8266 WeMos module with an ENS160+AHT21 CARBON Dioxide CO2 eCO2 TVOC Air Quality And Temperature And Humidity Sensor.
STEP 1:
I never found much information about this cheap module from AliExpress.
https://www.aliexpress.us/w/wholesale-ens160%2Baht21.html?spm=a2g0o.detail.search.0
This module combines two sensors on one module making it very easy to connect to. I used the I2C to interface with a ESP8266 WeMos module. I think you can use any microcontroller that has a I2C interface. I only use these cheap sensors to see if things change over time. They are not accurate enough for exact numbers.
VIN is 5 volts..my unit had 2 voltage regulators on it for the sensors. 65K5=1.8V and a 662K 3.3V; both have max input of 6 volts. The 3.3V pin is a low current output from the 66K5 regulator-don't use.
These are the libraries I used.
Adafruit AHTX0
ENS160 - Adafruit Fork
Below is the sketch I used for basic testing.
Tim TEST ENS160+AHT21
a 20231201 start testing.
ENS160 - Digital Air Quality Sensor
This is an example for ENS160 basic reading in standard mode
Updated by Sciosense / 25-Nov-2021
#include <Wire.h>
int ArduinoLED = 2;
///// AHT20 start
#include <Adafruit_AHTX0.h>
Adafruit_AHTX0 aht;
//Variables Tim, reused same names so I did not have to change much.
int tempC; //To store the temperature in C
int tempF; //temp in F
int humidity; //To store the humidity
///// AHT20 end
#include "ScioSense_ENS160.h" // ENS160 library
//ScioSense_ENS160 ens160(ENS160_I2CADDR_0); //0x52
ScioSense_ENS160 ens160(ENS160_I2CADDR_1); //0x53..ENS160+AHT21
SETUP function
initiate sensor
void setup() {
Serial.begin(9600);
while (!Serial) {}
//Switch on LED for init
pinMode(ArduinoLED, OUTPUT);
digitalWrite(ArduinoLED, LOW);
Serial.println("------------------------------------------------------------");
Serial.println("ENS160 - Digital air quality sensor");
Serial.println();
Serial.println("Sensor readout in standard mode");
Serial.println();
delay(1000);
Serial.print("ENS160...");
ens160.begin();
Serial.println(ens160.available() ? "done." : "failed!");
if (ens160.available()) {
// Print ENS160 versions
Serial.print("\tRev: "); Serial.print(ens160.getMajorRev());
Serial.print("."); Serial.print(ens160.getMinorRev());
Serial.print("."); Serial.println(ens160.getBuild());
Serial.print("\tStandard mode ");
Serial.println(ens160.setMode(ENS160_OPMODE_STD) ? "done." : "failed!");
// AHT20 start
Serial.println("Adafruit AHT10/AHT20 demo!");
if (! aht.begin()) {
Serial.println("Could not find AHT? Check wiring");
while (1) delay(10);
Serial.println("AHT10 or AHT20 found");
//AHT20 end
} //end void setup
MAIN LOOP FUNCTION
Cylce every 1000ms and perform measurement
void loop() {
///// AHT20 start
sensors_event_t humidity1, temp; //Tim had to change to humidity1
aht.getEvent(&humidity1, &temp);// populate temp and humidity objects with fresh data
tempC = (temp.temperature);
tempF = (temp.temperature)*1.8+32;
humidity = (humidity1.relative_humidity);
Serial.print("Temperature: ");
Serial.print(tempC);
Serial.println(" degrees C");
Serial.print(tempF);
Serial.println(" degrees F");
Serial.print("Humidity: ");
Serial.print(humidity);
Serial.println("% rH");
delay(1000);
///// AHT20 end
// Give values to Air Quality Sensor.
ens160.set_envdata(tempC, humidity);
ens160.measure(true);
ens160.measureRaw(true);
Serial.print("AQI: ");Serial.print(ens160.getAQI());Serial.print("\t");
Serial.print("TVOC: ");Serial.print(ens160.getTVOC());Serial.print("ppb\t");
Serial.print("eCO2: ");Serial.print(ens160.geteCO2());Serial.println("ppm\t");
//Serial.print("R HP0: ");Serial.print(ens160.getHP0());Serial.print("Ohm\t");
//Serial.print("R HP1: ");Serial.print(ens160.getHP1());Serial.print("Ohm\t");
//Serial.print("R HP2: ");Serial.print(ens160.getHP2());Serial.print("Ohm\t");
//Serial.print("R HP3: ");Serial.print(ens160.getHP3());Serial.println("Ohm");
delay(1000);
} //end void loop
