Introduction: ESP8266-12 Blynk Wireless Temperature LM35 Sensor
ESP8266-12 blynk wireless temperature LM35 sensor
in this project using a esp8266, to show the temperature LM35 sensor on your smartphone or tablet.
if you have available sensors DHT11 DHT22 or you can use the following Instructable
DHT11 sensor
ESP8266-12 blynk wireless temperature, humidity DHT 11 sensor
DHT22 sensor
ESP8266-12 blynk wireless temperature, humidity DHT22 sensor
Step 1: Materials
ESP8266-12 (esp8266-7, ...... , esp8266-12e)
LM35 temperature sensor (10mv /°c)
power regulator 3,3v-5v
Step 2: Connections
ESP8266-12
VCC +3,3v
CH-PD +3.3v
ADC ---- pin2 (LM35)
GND ground
GPIO5 ground
LM35 sensor
pin 1 +3,3v
pin 2 output .---- ADC (ESP8266-12)
pin 3 ground
Step 3: Blynk App
store app
configure blynk
create new project ( use hardware model esp8266 )
generate AUTH TOKEN
send E-mail TOKEN ( copy TOKEN in the esp8266 sketch)
in the app Blynk use Value Display widget or Gauge widget
Step 4: Sketch
sketch
blynk library
SimpleTimer library
to programming the ESP8266-12, I use ide arduino 1.6.5 and CP2102 3.3V USB To UART Serial Interface Module Adaptor ( do not connect the power of the CP2102 to esp8266-12).
SP8266 sketch
change the sketch in the following lines with your data
char auth[] = "xxxxxxxxxx"; //insert here your token generated by Blynk
Blynk.begin(auth, "ssid", "password!"); //insert here your SSID and password
note
ADC
If you use ide arduino ADC ---- pin 17
range voltage 0-1.0v
range units 0-1024
Step 5: Thanks
thanks by catoplepa
22 Comments
6 years ago
Nice one! Do you have any idea about how much power it consumes? From my understanding the ESP 12 shouldn't go above 200mA, but the ESP-01 has peeks over 300mA... and my batteries goes crazy in transmissions :(
Other wireless temperature example
6 years ago
My values are out of whack when I use the equation 1/1024 * 100. At 19 deg c, I get values around 12.00 for the temperature and around 125 for the analogRead on the tempPin.
The sensor works properly without the ESP on an Arduino.
Any ideas what might be causing this?
Reply 6 years ago
Just some details.
The output voltage from the sensor seems to be right (~190mV at 19 deg C). However, when I measure the voltage from ADC pin to GND pin on the ESP-12F, it's around 130mV (also indicated by the analogRead function)-- which seems a bit far from the 1V-1024 conversion.
Reply 6 years ago
For some reason, 1.5V instead of 1V seems to be an appropriate conversion in my case but I have no idea why -- I know that ADC pin goes from 0 to 1V (or should at least).
7 years ago
Hi you wrote GPIO5 to GND but on the pic GPIO15 is grounded?
7 years ago
please make one with ds18b20 sensor on a digital pin.!!
7 years ago
Hello all, problem solved.
It seems that it is very important to place home made functions in front of
void setup() and
void loop()
7 years ago
Hi, kyuubi87
Please check that you have library SimpleTimer in the folder
Thanks
8 years ago
Hi, clebrw
Thanks
Reply 7 years ago
I have the same problem at compile
"error: 'sendUptime' was not declared in this scope"
i have everything in same folder :-(
8 years ago
Farenheit = (Celsius*1.8)+32
8 years ago
Yeah, it works. thank you catoplepa.
What i have to change in the code to get Celsius and not Farenheit?
8 years ago
OK thank's
I wish there was a sketch for DS18B20.
I'll be waiting I believe will be written.
8 years ago
Hi Homerruma
not because the two sensors are completely different, LM35 is an analog sensor while DS18b20 is a digital sensor.
the DS18b20 is certainly compatible with both Blynk that ESP8266 but that created a new sketch
8 years ago
Hello
Is it possible to replace the LM35 sensor with DS18B20?
8 years ago
I'm sorry but I do not know what it means
8 years ago
Hello,
When I try to load the sketch, after a few seconds, the message appears.
I use a 3.3V 3A capable.
I tried many baud rates...
But I finally I found that the module is in 74880 bauds! Yes 74880.
When I power it I receive these 2 lines :
But there is no 74880 baud rate in arduino IDE.
Any idea of what does this message means?
Thanks a lot.
8 years ago
Hi, whogarden
It happens while loading the sketch or after?
you can try to put the Baud rate 9600
Also check, that you have sufficient power (3.3 V).
RX<->TX
TX<->RX
and check your wiring
8 years ago
Hello,
With the sketch below, I have the error :
warning: espcomm_sync failed
error: espcomm_open failed
And no answer to AT command.
Any idea about baud rate?
Something else?
Thanks.
8 years ago
try to load this sketch
http://docs.blynk.cc/#hardware-set-ups-esp8266-standalone
Or test At comand
http://forum.hobbycomponents.com/viewtopic.php?f=74&t=1777
....Catopl
