ESP8266 IOT Using Arduino and ThingSpeak
Intro: ESP8266 IOT Using Arduino and ThingSpeak
Internet of Things (IoT) is a concept that aims to expand the benefits of connected internet connectivity continuously -the ability to share data, remote control, and etc, as well as on objects in the real world. For example, food, electronics, collectibles, any equipment, including living things that are all connected to local and global networks through embedded and active sensors.
Here is an example program of Arduino IoT using ESP8266 Wireless Module -how to send data in the form of random value, which can be monitored from anywhere by utilizing the free IOT service provider -ThingSpeak.
STEP 1: Materials You Need
You will need:
- ESP-8266 Wireless Module
- SFE Duino
- Male to Female Jumper Wires
STEP 2: Setup
Connect SFE Duino and ESP-8266 Wirelss Module with jumper wires as schematic above.
STEP 3: Connect With ThingSpeak
Once you've connected the materials, visit ThingSpeak and create an account there. And then, create a new channel.
STEP 4: Code
After that, you can upload the code below and make sure to fill the data as yours -start from API key and Field name, and also Access Point setting which will be connected to ESP-8266 Wireless Module (AP and Password).
#include
#define DEBUG true
#define RX 2
#define TX 3
String HOST = "api.thingspeak.com";
String PORT = "80";
String AP = "AP NAME";
String PASS = "AP PASSWORD";
String API = "CJZ1G46URZWEGRVR";
String field = "field1";
int countTrueCommand;
int countTimeCommand;
boolean found = false;
int valSensor = 1;
SoftwareSerial esp8266(RX,TX);
void setup() {
Serial.begin(9600);
esp8266.begin(115200);
sendCommand("AT",5,"OK");
sendCommand("AT+CWMODE=1",5,"OK");
sendCommand("AT+CWJAP=""+ AP +"",""+ PASS +""",15,"OK");
countTrueCommand = 0;
void loop() {
String getData = "GET /update?api_key="+ API +"&"+ field +"="+String(valSensor);
switch(countTrueCommand) {
case 0: sendCommand("AT",5,"OK");break;
case 1: sendCommand("AT+RST",10,"invalid");break;
case 2: sendCommand("AT+CIPMUX=1",5,"OK"); break;
case 3: sendCommand("AT+CIPSTART=0,"TCP","+ HOST +","+ PORT,15,"OK"); break;
case 4: sendCommand("AT+CIPSEND=0," +String(getData.length()+4),4,">"); break;
case 5: esp8266.println(getData);delay(1500);countTrueCommand++; break;
case 6: sendCommand("AT+CIPCLOSE=0",5,"OK"); break;
case 7:
Serial.println(valSensor);
Serial.print(getData);
Serial.print(",");
Serial.println(getData.length());
valSensor = random(100000); // random value, change with sensor value if using sensor
delay(10000);
break;
void sendCommand(String command, int maxTime, char readReplay[]) {
Serial.print(countTrueCommand);
Serial.print(". at command => ");
Serial.print(command);
Serial.print(" ");
while(countTimeCommand < (maxTime*1))
esp8266.println(command);//at+cipsend
if(esp8266.find(readReplay))//ok
found = true;
break;
countTimeCommand++;
if(found == true)
Serial.println("OYI");
countTrueCommand++;
countTimeCommand = 0;
if(found == false)
Serial.println("Fail");
found = false;
STEP 5: Monitor It!
After you upload it, make sure that the Wifi you used connected with internet connection. Then, open serial monitoring to see AT Command data. Data which sent is a random data. You can change it with data of sensor or etc. Here is the value of monitoring result after many data processing.
20 Comments
Muchtar 1 year ago
MonaA 2 years ago
MonaA 2 years ago
MonaA 2 years ago
if i have tow fields How does the code become?
Tarun1114 4 years ago
Thanks in Advance.
I have purchased the ESP8266 module at
http://uitechies.co.in/BBBcircuits/product.php?product=serial-wi-fi-wireless-transceiver-module-iot-esp8266
bwengyeduncan.bd 3 years ago
AarohanS1 3 years ago
DePaul_250 3 years ago
I need help about connecting NodeMCU on Wifi with no password
_#include <ESP8266WiFi.h>
const char *ssid = "Your wifi Network name";
const char *pass = "Network password";_
SharadD3 4 years ago
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Dasari\AppData\Local\Temp\arduino_modified_sketch_505484\Sserial.ino: In function 'void setup()':
Blink:33:39: error: 'send_command' was not declared in this scope
send_command("AT+RST\r\n",2000,DEBUG);
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
sayeda24 4 years ago
can you post right code
93ahire 6 years ago
/*this is 100% working program just change your AP name pass and things speak password*/
#include <SoftwareSerial.h>
#define DEBUG true
#define RX 8
#define TX 7
String PORT = "80";
String AP = "XXXX";//your AP name
String PASS = "XXXX";\\your AP password
String API = "XxxXPF**V6**OEIL";//your API
int valSensor = 1;
void setup() {
Serial.begin(9600);
Serial.println("AT+CWJAP=\""+AP+"\",\""+PASS+"\"");
sendCommand("AT+CWJAP=\""+AP+"\",\""+PASS+"\"",15,"OK");
void loop() {
String readDat="GET https://api.thingspeak.com/channels/9/feeds.json?...
case 1: sendCommand("AT+RST",10,"OK");break;
case 3: sendCommand("AT+CIPSTART=0,\"TCP\",\""+ HOST +"\","+ PORT,15,"OK"); break;
case 7:
Serial.print(",");
delay(10000);
break;
Serial.print(" ");
found = true;
break;
countTimeCommand++;
if(found == true)
countTrueCommand++;
if(found == false)
found = false;
RuodiW 6 years ago
after running this program it is working, but always fail at the AT phase, and shows 0. at command => AT Fail, how to fix this problem?
Krusher99 5 years ago
annesha 5 years ago
Jeff Quek 5 years ago
Hi, can I replace the random(10000) with flow sensor value? how to replace it? I tried, it show in serial monitor but no upload in the thingspeak. Please advise. Thank you.
DinkarJ 6 years ago
Error in the code can be corrected as follows--
in line 1 :
and change the code at case 3 as :
case 3: sendCommand("AT+CIPSTART=0,TCP,"+ HOST +","+ PORT,15,"OK"); break;
humidif 6 years ago
What is the baud rate to be fixed
kishanr19 6 years ago
While compiling, i get this error
expected ')' before 'TCP'
After that, I added '+' to front and back of TCP. Then It gave
'TCP' not found in this scope.
harshkat 6 years ago
some error in the given code
