Earphone Untangler - Simple to Make!
Intro: Earphone Untangler - Simple to Make!
This simple tool will make sure your earphones will never be tangled again!
STEP 1: Step 1: Gather the Things You Will Need!
You will need:
1x saw
1x sanding paper
1x hammer
1x file
1x scrap wood
4x small nails
STEP 2: Step 2: Saw the Wood
Saw the wood in two pieces of 1cm thick and saw another piece that is around 6 cm log and 1cm thick.
2x piece of wood (1cm thick)
1x piece of wood (6cm long, 1 cm thick)
STEP 3: Step 3: Round Off the Edges
First gat your file and round of any sharp edges. after that, get your sanding paper and smoothen out the rest.
STEP 4: Step 4: Put the Pieces Together
Get one of the short wooden pieces and the long wooden piece and attach them to each other using two nails (as seen in the video), then repeat this step on the other end.
STEP 5: Step 5: Cutting Grooves
The next step is to cut two grooves at each end of the tool as seen in the video.
STEP 6: Sten 6: Wrapping the Earphones Around!
The final step is to warp the earphone around the tool. Get the end where the 3.5mm headphone jack is located and place it in one of the grooves. Then once it lies tightly in the groove wrap the entire length of the earphone around the tool. Leave about 2 cm and place the other end in the other groove. You just created your very own anti-tangle tool!
Swansong 7 years ago
I need one of these :) If you include some progress photos for the individual steps it will get more attention on the site and be possible to be featured. https://www.instructables.com/id/How-to-Create-a-F...
