Introduction: Earring Making Ideas--How to Make Cute Santa Claus Earrings for Girls
Wanna try Santa Claus earrings? Check here! Today’s Pandahall tutorial on how to make cute Santa Claus earrings for girls will catch your eyes a lot!
Step 1: Materials Needed for the Santa Claus Earrings:
4mm Round Red, Green, Yellow and Black Seed Beads
4mm Round Pink Seed Beads
4mm Round White Seed Beads
Earring Hooks
0.2mm Clear Transparent
Fishing Thread
Scissors
Step 2: Prepare the First White Beading Line
1st, trim off a proper length of clear transparent fishing thread and add it on a needle, then slide nine white seed beads on it;
2nd, cross the fishing thread back through the eighth and sixth white seed bead;
3rd, add a white seed bead on the needle and then thread it through the fourth and second white seed bead;
4th, cross the fishing thread back through all the white seed beads and then add a white seed bead on the needle and thread it through the last white seed bead.
Step 3: Make the Front Three White Beading Lines
1st, add a white seed bead on the needle and thread it through the eighth white seed bead;
2nd, thread the needle through the next white seed bead and slide three white seed beads on it;
3rd, thread the needle through the fourth white seed bead on the first beading line, then add a white seed bead on the needle and cross it through the second and first bead;
4th, slide a white seed bead on the needle and thread it through the third white seed bead;
5th, add a white seed bead on the needle and cross it through the first top white seed bead;
6th, continue to slide a white seed bead on the needle and thread it through the first beading line;
7th, add a white seed bead on the needle and thread it through the next top bead.
Step 4: Make the Fourth White Beading Line
1st, slide a white seed bead on the needle and thread it through the next top white seed bead;
2nd, add a white seed bead on the needle and then thread it through the next seed bead;
3rd, continue to add a white seed bead on the needle and then thread it through the next seed beads;
4th, slide a white seed bead on the needle and then thread it back through the next to three white seed beads, and add white seed beads on interval;
5th, repeat the same ways one time to get the fourth white beading line.
Step 5: Add Pink and Red Seed Beads
1st, add a red seed bead on the needle then thread it through the top third and fourth white seed beads, then slide a white seed bead on the needle and cross it through the next top white seed bead;
2nd, slide a white seed bead on the needle and thread it through the second top white seed bead;
3rd, slide a pink seed bead on the needle and thread it through the next white seed bead, and continue to add a white seed bead and thread it through the red seed bead;
4th, add other pink seed bead in the same way.
Step 6: Continue to Add Beads
1st, add a pink seed bead on the needle and then thread it through the next pink seed bead, then continue to add a pink seed bead on the needle and thread it through the next white seed bead;
2nd, add a white seed bead on the needle and thread it through the next white seed bead, then add other three pink seed beads on this side in the same ways;
3rd, after repeating the same ways two times, then add the yellow and black seed beads in the same ways, please see the showing picture below.
Step 7: Finish the Outline of the Santa Claus
1st,add a red see bead on the needle and thread it through the next white seed bead, then slide a yellow seed bead and cross it through the black seed bead;
2nd, slide a yellow seed bead on the needle and thread it through the next yellow seed bead and continue to add a yellow seed bead, then cross it through the black seed bead;
3rd, continue to add a yellow seed bead , then thread it through the next white seed bead;
4th, slide two white seed beads on the needle and thread it back through the next seed bead;5th, slide the green seed bead in the same ways.
Step 8: Add the Red and Green Seed Beads
1st, slide a red seed bead on the needle and thread it through the next red seed bead, then add a red seed bead and thread it through the next white seed bead;
2nd,continue to add white seed beads on interval;
3rd, slide a red seed bead and thread it through the next green seed bead, then slide two green seed beads on the wire and thread back through the next red seed bead;
4th, continue to slide red and green seed beads like the showing picture below.
Step 9: Finish the Santa Claus Earrings
1st, add five3 white seed beads on the fishing thread, then thread it through the earring hook and cross the fishing thread back and hide it;
2nd, make other earring in the same ways.
Step 10: Time for the Final Look of the Cute Santa Claus Earrings:
Wow, what a lovely seed beads earrings! Maybe it costs a little your time and energy to make such a stunning earrings, but it really deserves! Right? If you are interested in the Pandahall tutorial, have a try! If you have any confusion, please feel free to ask me or leave a comment. Hope you a nice try and have a good day~
