Earrings and Necklace With Petals With UV Resin
Intro: Earrings and Necklace With Petals With UV Resin
Hello everyone, today I bring a very simple and for me, very nice project. They are earrings and a matching necklace made of real petals. I want to warn you that you must wear gloves to avoid staining. I hope you like it.
Hola a todos, hoy traigo un proyecto bastante simple y para mi, muy bonito. Son unos pendientes y un collar a juego hechos de pétalos reales. Quiero avisar que debes usar guantes para evitar mancharte. Espero que os guste.
STEP 1: Dry Your Petals
You must choose the petals, I chose the bougainvillea flower, put them in a book and let them dry for several days. The petals I used are very fine and took only 3 days to dry.
(There is a way to dry petals in a few minutes: take two tiles with nothing metallic on them, put two paper napkins on the shiny side and put the sheet in between for 1 minute).
Debes elegir los pétalos, yo elegí la flor de la buganvilia mételos en un libro y déjalos secar varios días. Los pétalos que usé yo son muy finos y tardaron solo 3 días en secar.
(Hay una manera de secar pétalos en unos minutos: coges dos azulejos que no tengan nada metálico pones dos servilletas de papel en la cara brillante y metes la hoja en medio 1 minuto.)
STEP 2: One Side
Put the petals you have chosen on the silicone base, pour UV resin and spread it with the nozzle or with a stick all over the petal, trying not to let anything come out of the petal.
Pon los pétalos que has elegido en la base de silicona, echa resina UV y extiéndela con la boquilla o con un palito por todo el pétalo, intentando que no salga nada fuera del pétalo.
STEP 3: Cure
Put it in the UV lamp for 2 minutes. If you notice that it is not completely dry, leave it for another 2 minutes. If you use sunlight it may take a little longer, but it also works.
Mételo en la lámpara UV 2 minutos. Si notas que no está seco del todo déjalo otros 2 minutos. Si usas la luz solar puede tardar un poco más, pero también funciona.
STEP 4: Other Side
When it is very hard, repeat these steps exactly the same on the other side.
Cuando esté bien duro, repite estos pasos exactamente igual por el otro lado.
STEP 5: File Edges
File the edges to remove the defects. See the difference?
Lima los bordes para quitarle los defectos. ¿Ves la diferencia?
STEP 6: Holes
Using the drill, drill holes for the hooks. Support it on a wooden base.
Con el taladro, haz los agujeros para colocarle los ganchos. Apóyate en una base de madera.
STEP 7: Hooks
Choose the rings and clasps, create your earrings and necklace. I chose the gold color because I think those two colors look great.
Elige las anillas y enganches, crea tus pendientes y collar. Yo elegí el color dorado porque creo que esos dos colores quedan muy bien.
STEP 8: Bonus
Of course, you can choose different shapes, colors and sizes, even if you don't get the shape you like you can trim the petal after drying! I hope you enjoy, thanks for reading!
Por supuesto, puedes elegir diferentes formas, colores y tamaños, incluso si no consigues la forma que te gusta puedes recortar el pétalo después de secarlo! Espero que te haya gustado, gracias por leerme!
