Gourdgeous Knit Pumpkins
Intro: Gourdgeous Knit Pumpkins
Fall decor has never been faster with the Gourdgeous (Gourds, get it?) Knit Pumpkins. Any beginner can make these in no time, using only a knit tube or rectangle sewn into a pumpkin shape. Each ball of recommended yarn makes 2 pumpkins. Customize the look by switching up colors, yarn thickness and needle size, or stem material.
Steps 1-12 are for knitting flat on straight or circular needles.
Steps 13-20 are for knitting in the round on circular needles, using the Magic Loop method.
Steps 21-24 are for knitting the i-cord stem on DPNs.
ABBREVIATIONS
- CO - Cast On
- st(s) - stitches
- Rnd(s) - Round(s)
- RS - Right Side
- WS - Wrong Side
- k - knit
- p - purl
- DPN(s) - double pointed needle(s)
No gauge; finished pumpkin size depends on amount of stuffing. Sample pumpkin is 6in wide and 3.5in tall.
STEP 1: Knit Flat
CO 37 sts.
STEP 2: Knit Flat
Row 1 (RS): (k2, p1) across to last st, k1.
STEP 3: Knit Flat
Row 2 (WS): p1, then (k1, p2) to end of row.
STEP 4: Knit Flat
Repeat last two rows 11 more times, for a total of 24 rows.
STEP 5: Knit Flat
Bind off and cut yarn, leaving a 30in long tail.
STEP 6: Knit Flat
Fold in half so edges of work are touching, right sides out.
STEP 7: Knit Flat
Make an Invisible Vertical Seam down the side using tapestry needle to create a tube.
STEP 8: Knit Flat
Pull yarn through every other stitch at end of tube and cinch closed. Secure with a knot but do not cut yarn.
STEP 9: Knit Flat
Fill open end with polyester fiberfill.
STEP 10: Knit Flat
Push tapestry needle with tail yarn through center of closed end, through the fiberfill, and out the open end.
STEP 11: Knit Flat
Weave tail yarn through every other end stitch and cinch tight, both closing the hole and pulling the pumpkin flatter.
STEP 12: Knit Flat
Secure with knot, trim yarn, and weave in ends.
STEP 13: Knit in the Round
CO 36 sts and join in the round. Place stitch marker at beginning of round.
STEP 14: Knit in the Round
Rnds 1-24: (k2, p1) around.
STEP 15: Knit in the Round
Cut yarn, leaving a 30” long tail.
STEP 16: Knit in the Round
Using tapestry needle, pull yarn through every other end st and cinch closed. Secure with knot but do not cut yarn.
STEP 17: Knit in the Round
STEP 18: Knit in the Round
STEP 19: Knit in the Round
Weave tail yarn through every other cast on st and cinch tight, both closing the hole and pulling the pumpkin flatter.
STEP 20: Knit in the Round
STEP 21: Stem
To make i-cord: CO 4 sts on one DPN.
STEP 22: Stem
Slide sts back to beginning of needle. Do not turn. Bring yarn behind the work to first st. k4.
STEP 23: Stem
Repeat until your i-cord is 7 rnds tall. Cut yarn, leaving a 10in long tail. Thread yarn through top 4 loops using tapestry needle.
STEP 24: Stem
Use remaining tail yarn to sew stem to pumpkin top. Alternatively, affix a twig or cinnamon stick using hot glue, or sew on a fabric stem.
