Introduction: Easter Bunny Trap
How to make an Easter Bunny Trap
Cardboard box, Hot Glue, Wheel, String Tape, Two cups, Rocks, Kinecks, Construction paper, Bait, Mat, and Clothespin
Step 1: Box
Get a box that can fit a bunny. 2 shoe boxes will be enough.
Step 2: Ramp and Pressure Plate
The second thing you need to do is build a pressure plate; what you wanna do is grab a clothespin and glue it to the bottom of the box and then get cardboard and glue it to the end of the clothespin where it will open the clothespin when pressure on it after your done with that you want to add a ramp where it’s a bit higher than the pressure plate.
Step 3: Add a Door and String to Hold the Door
The third step is you will need a door to trap the bunny so what you need to do is grab the string and attach it to the clothespin the other end is going to be attached to your door put the string where the door can close.
Step 4: Add Pulley for Door and Add Weight
Grab 5 Kinect sticks use two to make a triangle and repeat. Once you did that grab the last Kinect stick and stick it in a wheel. At last, connect the sticks with the wheel on the corners of each triangle and tape it to the box.
This pulley will help keep the box door open without putting too much tension on the box. After that put rocks in the cups and hot glue them to the box with adult supervision.
Step 5: Decorate and Bait
After you finish building the Easter Bunny Trap you can decorate it to make it more like home to the bunny. Once you finish the decorating you can add the bait at the end of the trap and wait for the bunny.
