Easy 5 Minute XBOX Rock Band Guitar Down Strum Fix
Intro: Easy 5 Minute XBOX Rock Band Guitar Down Strum Fix
This is my first instructable ever, so please be nice!
My buddy was too lazy to look online for solutions, and actually fix his rock band guitar - so I stole it, the game, his other guitar, and his mic. It wouldn't register down strums, and as you know, up strumming an entire song is just no fun.
I have to give credit to Ben Sones from Quarter To Three. His fix was the inspiration to mine. Plus his seems more reliable.
http://www.quartertothree.com/game-talk/showthread.php?t=40188
STEP 1: Open It Up!
First you've gotta get your guitar open. Flip over the guitar to the back side, and take out all the screws. You don't need to take out the tiny battery compartment screw. Take note of where everything goes too since there are three lengths of screws. I used an outline of the guitar and plugged the screws in the outline where they go in the guitar.
STEP 2: Finding the Contact!
Once you get it open you're going to see a bunch of electrical stuff of which I have no idea what most of it is. Wires, connectors, magic, flux capacitors, etc. There is one thing you need to find, and it's called the "Contacts". It's a big word, I know.
The strummer works by leveraging the other side to push contacts together, which then allow signal to be sent to the XBOX. The problem was that my contacts weren't contacting eachother.
Now remember, the contacts for the down strum are up, and vice versa.
STEP 3: Fixing the Contact!
To find out if it is truly the contacts at fault, hook up your guitar and turn on your XBOX. Move the top contact towards the bottom contact so they touch, and see if it moves your menu selection. If it does, congratulations, your problem is easily solvable. If not, this instructable, and by extension myself, am of no use to you. If it does, then you just have to devise a way for the contacts to meet more consistently.
Some will say to play around with the tension screw. I say why do that when you can be lazy.
What I did was put in a spacer behind the upper contact, and then tried down strumming. You'll see the corner of my gas bill acting as a spacer in the picture below. I found it to be a bit thick - the strumming was too sensitive - but it worked!
Now obviously an entire gas would be ridiculously big to fit inside the guitar, so I tore off a corner of the envelope. I found that a little piece, folded over (to equal two sheets), did the job perfectly. I didn't worry about it coming out again since the contact's pressure against the mounting nub behind it was pretty strong. If it comes out again, I'll just open it back up. I played a song with this fix, and it works great.
Please let me know if this works for you too!
3 Comments
bionicguppie 14 years ago
SWBailey 14 years ago
stunami 14 years ago
