Introduction: Easy Beebeecraft Project on Making an Adorable Elegant Bracelet With Pearls
Summary: Pearl jewelry always looks gorgeous, People wearing the pearl jewelry look very elegant. Looking for DIY pearl bracelets? We are going to make a pearl bracelet with the pearl beads in Beebeecraft.com. You can follow it.
In today’s project, there is an adorable beaded bracelet design. Pearl jewelry is the essential ornament for the big occasion and party. The combination of pearl beads in red and white color makes the pearl bead flower bracelets charming.
Step 1: Jewelry Craft Supplies Needed in DIY the Pearl Bead Bracelets:
PandaHall Elite 4-10mm Crimson glass pearl beads
PandaHall Elite 4mm white glass pearl beads
2mm Brass Round Crimp Beads
8x4x3mm Iron Round Spacer Beads
Jewelry Basics Class Kit
0.2mm Clear Thread Nylon Wire
BENECREAT Long Nose Pliers
Step 2: String and Fix the Clasp on Wire
1st, cut a piece of 0.2mm white fishing wire;
2nd, fix the clasp on the wire by using a crimp bead, squeeze the crimp bead on the wire by using the jewelry making tools Long Nose Pliers, make sure the wire is divided into two parts;
Step 3: Bead the Bracelet Pattern
1st, add eight 4mm white glass pearl beads to one wire and five 10mm crimson on the other wire, then cross two wires through one 10mm crimson glass pearl bead;
2nd, repeat the 1st process with adding the same quantity glass pearl beads, the quantity of the bead pattern depends on your wrist;
3rd, add one crimp bead, add another jumpring on clasp, connect it with the clasp.
Step 4: The Final Look of This Beautiful Simple Pearl Bracelet:
Do you love the bead bracelet designs? The red and white pearl bead flower bracelets can be sent to your close friends. During the DIY process, you can use your imagination to match pearl beads in different colors to create other colored bead flower bracelet. Have a try!
