Easy Chopping Block Handle
Intro: Easy Chopping Block Handle
I have a nice stump that i use to split wood for my fire, but i often need to move it around the yard to chop and then back into hiding when it's not in use. It isn't particularly heavy but i wanted a way to carry it with one hand so that i could carry my maul in the other.
Solution
I decided to use some extra sheet metal i had to fashion a make shift handle. A sheet of metal is pretty inexpensive, but if you need to buy some you might as well buy a cheap strong gate handle or something for the same price.
STEP 1: Cut the Metal
I cut 14" x 14" piece of metal. I was mainly thinking that i wanted a thick piece long enough to bend into a handle. You should measure the size of your stump before cutting the metal.
STEP 2: Fold the Metal
I started by folding the edges inward so that there were no sharp edges exposed. Then i continued to fold it in half over and over until i had a piece that fit nicely in my hand. At then end it got a little hard to manipulate. I enlisted the use of my car, slowly rolling over the metal to bend and fold it.
STEP 3: Attach the Handle
I first sanded the stump down a little bit to avoid splinters when picking it up.
Finally i used some wood screws and washers that i had on hand to attach the handle to the stump. I needed a little bending and folding to get the angle correct for the handle shape.
STEP 4: Test It Out
That's it! So far it seems to be working great. I will update this later if i find it isn't secure enough or if i make other modifications.
5 Comments
PowellMade 9 years ago
dtsunekawa 9 years ago
ClenseYourPallet 9 years ago
LanaM 9 years ago
very cool
amberrayh 9 years ago
That was nice of your car to help you with the folding. Thanks for sharing! Congratulations on your first Instructable! I hope we see many more from you.
