Easy Halloween Pumpkin Carving Tool
Intro: Easy Halloween Pumpkin Carving Tool
This is my first attempt at submitting an Instructable. I decided to go with this super simple, super cheap, and extra tough pumpkin carving tool.
STEP 1: Gather the Parts
The parts list is really simple:
2-4" long piece of copper tubing (I used 1/2")
Course toothed Jigsaw blade
STEP 2: Clean Inside of Tubing
I cleaned the inside of the tubing with a small wire brush. This facilitates sweating a little solder in later to firm up the assembly
STEP 3: Mark the Blade
Put a mark on the blade to show that it is sufficiently installed. I made sure to go a couple of teeth down. This makes the teeth dig into the couple and made for a stronger joint. You can see my red mark in this picture.
STEP 4: Squeeze the Copper
Mount the copper tubing in a vise by about 1/2". Squeeze the jaws down until there is just enough room to insert the blade. Then insert the blade to your mark and squeeze the copper the rest of the way down around the blade. I positioned the copper in the vise a couple of times to crimp just off the edge of the blade to get a tight grip on the blade.
STEP 5: Sweat the Opening
Using traditional soldering techinue, I sweat some solder into the joint. This keeps it from working open and loosening around your blade. My first attempt did not include cleaning the inside of the copper, so this step wasn't possible. It probably isn't totally necessary. You can always tighten it back up in the vise if it works loose.
STEP 6: Finished Tools
You can use a variety of different blades to suit your needs. These are sharper and more rigid than any carving tools you can buy.
13 Comments
beecroft 10 years ago
FBookhoo 10 years ago
Thanks
getoffamycloud 10 years ago
bptakoma 10 years ago
Take your extra copper tubing and cut at an angle with a hacksaw. You now have an easy small circle cutter for your pumpkin. Just stick it in and twist around.
ghaines1 10 years ago
lalegría 10 years ago
planefixxer 10 years ago
marhar 10 years ago
Bettybstt 10 years ago
W8L42B9 10 years ago
Showler 10 years ago
