Introduction: Easy Make PCB Board
About: Hi, I'm Steve! I'm a creative mind with a knack for technical skills—I can build just about anything you can dream up! From innovative projects to captivating designs, I bring ideas to life with passion and pr…
HI Guys I'm Steve From India
And Today i'm Going to Show to How To make a PCB Board.
Click Here to See The Video
Step 1: What You Need
  • Copper Clad click
  • Photo Paper
  • Laser Printer
  • Ferric chloride
  • PCB Drill click
  • Cloth Iron
Step 2: Now Come to Work
I'll do step by step
  • Print Out Your PCB layout in photo paper with Laser Printer Only
  • Cut The Copper Clad in The Same size to match the layout dimension
  • Now Put The Paper onto The Copper Clad and Press With The Hot IRON
  • Now You Need a Bowl of Water
  • Put The PCB into The Water Let it soak For Around 30 minutes
  • Now carefully Remover The Paper From Board
  • After Removing The paper
  • You need to put some of Ferric chloride in a container with little water
  • Now put the PCB into the Ferric chloride Solution
  • After 20-30 minutes You Are done to take the PCB OFF
  • Now clean the PCB with some water
  • Now You Need a acetone and cotton ball to remove the black part
  • After Doing that you need to drill The holes for The components
  • Now Place your components and solder it
Step 3: You Are Done
  • Your PCB is Competed Your PCB will Look Something like This
