Introduction: Easy Marshmallow Shooter
Here are instructions to make a simple marshmallow shooter that anyone can make with simple tools and PVC pipe.
Step 1: Materials
Required:
1 Long section of 1/2" diameter PVC pipe.
2 T connecters
1 Pipe cutter
1 Nickel
1 Bag of mini marshmallows
Use a pipecutter to cut the PVC. Mouseover the parts below to see approximate lengths of each pipe.
Step 2: Place Nickel in T Connector
Place the nickel inside the bottom hole of one of the T connectors. This part will be where you place the handle of the gun and seals the barrels of the shooter.
Step 3: Add the Handle to the T
Insert the 4" PVC pipe to the bottom of the T connector where you placed the nickel.
Step 4: Adding the Mid Section of the Barrel
Next, insert the 4" PCV pipe into the T connector. This is the middle part of the shooter barrel.
Step 5: Adding the Mouth Piece
Then, insert the 2" PCV pipe (mouth piece) to the open end to the T connector.
Step 6: Adding the Second T Connector
Place the second T connector on the end of the mid barrel section. The T connector should have the middle hole facing up and tilted slightly to the left or right side depending on which hand you prefer to use when loading marshmallows.
Step 7: Add Ammo Clip
Insert a 4.5" section into the top of the T connector you just added. This is where you will load the marshmallows.
Step 8: Add the Rest of the Barrel
Add the last section of PVC pipe onto the T connector. The shooter is now complete and ready for marshmallow action.
Step 9: Loading the Shooter
Insert mini marshmallows into the ammo clip.
Step 10: Fire When Ready!
You are now ready for the marshmallow amageddon.
4 Comments
8 years ago on Introduction
I made a simpler version.
10 years ago on Introduction
use bigger pipe and bigger marshmellows
10 years ago on Step 10
Understandable, detailed, and one step directoins. Great job guys but were do you suggest I buy PVC pipes?
It is best to buy it at Lowe's or The Home Depot or any home improvement store.
