Easy One Round Crochet Snowflake
Intro: Easy One Round Crochet Snowflake
Let's get Christmas ready!!! Decorating Christmas tree is probably one of the most exciting things to do with your family during the holiday season. Crocheted snowflakes are a beautiful way to add a handmade touch to Christmas Home Decor hey are the perfect way to add a touch of winter charm to your home.
Today am sharing the pattern for a Easy One Round Crochet Snowflake. This crocheted Snowflake is super easy to make. It is just a One Round Pattern. The Points are the snowflake is made with Picot Stitches. They are really quick and fun to whip up. You can have a couple of Crochet Snowflakes in no time at all.
You can use this Snowflake for may other projects too. Apart from using them as Ornaments for your Christmas Tree, you can also add them to gift bags or string them into garlands or use them on you Holiday Cards.
Cotton Yarns are the best for making this Snowflake Pattern. You can also use light weight thread yarns to make a Lacy Crochet Snowflake.
4 inches
Checkout https://rajiscrafthobby.blogspot.com/2023/11/easy-one-round-crochet-snowflake.html
STEP 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
STEP 2:
Let's Start:-
Start with a Magic Circle.
**Chain 4.
1 Extended Treble Crochet Cluster Stitch in the circle.
Chain 5 Picot (i.e. Chain 5 and make a Slip Stitch into the bottom stitch)
Chain 7 Picot.(i.e. Chain 7 and make a Slip Stitch into the bottom stitch)
Chain 5 Picot.(i.e. Chain 5 and make a Slip Stitch into the bottom stitch)
Chain 4.
Slip Stitch into the circle.**
Repeat from ** to ** 5 more times(total 6 points made)
Pull the yarn end to close the gap and weave off.
How to make a Treble Crochet Cluster??...here it is.....!!
- **Yarn over hook 2 times, insert hook in the Stitch and Pull up a loop.
- Yarn over, pull through First loop only - 4 loops on the hook
- Yarn over, pull through First 2 loops - Still 4 loops on the hook.
- Yarn over, pull through next 2 loops - 3 loops on the hook.
- Yarn over, pull through next 2 loops - 2 loops on the hook.**
- Repeat the above step i.e from ** to ** 2 more times.
- (This is same as doing a Extended Treble Crochet Stitch. It is just that , you don't finish the Extended Treble Crochet Stitch and continue doing the first part of the Stitch again and again untill you have 4 loops on the hook).
- Yarn over and draw the yarn through all 4 loops on the hook.
- Chain 1.
- That's 1 Extended Treble Crochet Cluster stitch made.
